Injector ID
Injector ID
Well the other day I hot rodded my truck for the first time since i bought it. It will break the tires loose in 2nd, 3rd and 4th gears when the turbo lights and black out the whole road. The guy i bought it from said it had 75hp injectors in it, and the fuel screw is only in to the collar. I've had a slight hazing problem since i got it and its almost impossible to pull a heavy load with due to the egt's getting out of control. Is it possible it might have pods in it and is there any way to tell with out taking the injectors out?
Mine say DELPHI just above the hold-down nut, its on the back side of them next to the valve covers but you can barely read them. And right above the DELPHI it has the number 9329 stamped on it, and lookin at it closer I think it says LUCAS on the exhaust manifold side then has a bunch of numbers.
TJ0993
Nov 8, 2007 10:27 AM
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
oscaroc
Apr 2, 2005 12:14 PM
