injection pump seal ?
Old Apr 26, 2015 | 11:10 AM
Brian.B's Avatar
hey guys im just now getting to trying to tear into my dodge,,,i didnt put loctite on the shaft seal for my injection pump and now my oil is full of fuel.....i have a few questions will my old seal be trashed,,,,do i buy a new one or clean and loctite this one ,,,,i probably havent ran the engine 5 minutes ,,,and can i buy the seal seperate from the whole dgk121 kit....and when doing the loctite,,i use red and how much,,,,and do i do the seal or the pump bore....thanks guys for any help.....
Old Apr 26, 2015 | 02:03 PM
How much fuel pressure are you running? Those front seals are really only good to about 15lbs.
Trying to buy just that front seal will probably cost at least half what the dgk121 costs.....so why not reseal the whole unit.
To do it properly I'd tear the entire IP down for another re-seal. I'd tear it down to a bare case, You don't want to get loctite inside the IP when installing the front seal. As for where to put the loctite......as long as you keep it off the rubber seal surface it doesn't really matter. I'd probably go with a thin coating on both surfaces.
Old Apr 26, 2015 | 03:18 PM
j_martin's Avatar
Assuming you're putting the seal in from the outside, With LocTite on the case, the excess if forced into the machine. On the seal, the excess is forced outside the machine. It's a crush fit, so there will be excess.
Old Apr 28, 2015 | 09:37 AM
Brian.B's Avatar
thanks guys,,,my truck is stock,,,,i just turned the pump up a little and moved the pump closer to the head to bump the timing a little,,,,but no fuel delivery system up grades or anything....i had just resealed the whole pump then about a week after the reseal it started missing and put fuel in my oil ,,but i didnt loctite the seal...i thought that was for high pressure deals.....lol....
Old Apr 28, 2015 | 03:26 PM
j_martin's Avatar
Like i said, seals are a crush fit. If they're driven straight in, holding a little pressure is normally a non issue. If they are punched in from side to side, rocking them, it can be a different story. LocTite will usually buy the grace needed for that scenario.
Old Apr 28, 2015 | 05:46 PM
Did you verify that it was the IP front seal? It could all so be the diaphragm on the lift pump.
Old Apr 30, 2015 | 07:07 AM
Brian.B's Avatar
I was hoping it was the lift pump but I put a new one on it and changed the oil ,,fired it up and let it run for a few seconds and it started missing and sputtering and smoking...I shut it down and sure enough fuel was in the oil.....
Brian.B
May 2, 2015 05:00 PM
sdseva
Aug 15, 2014 06:09 PM
tommurray
Feb 23, 2014 10:38 AM
SSV1761982
Jun 24, 2004 11:15 AM
