injection pump
Old Jun 11, 2003 | 06:21 PM
CurtisvilleCummins's Avatar
injection pump
Somebody already messed with the main pump screw dont know where im at, can i turn it the whole way in, or the whole way out to find where im at, where should i be for the most fuel, thank you<br> <br>
Old Jun 11, 2003 | 06:28 PM
Monty's Avatar
Re:injection pump
First off...I wouldnt turn it in anymore without at least a pyrometer. Turning the screw in or clockwise will give you more fuel. However, turning the screw all the way in has caused a few runaways on some trucks. The best advice I can tell you is to play with the settings a little and find the sweet spot. Go in small increments. When you get to the point where it takes a while for the RPMS to come down when revving it up. You are right at the brink of a runaway. I have my screw turned in about a 1/4 turn from where the collar was welded on and the screw is hard to turn. Seemed if I went any further, the RPMS were SLOOOOW to come down in between shifts.
Old Jun 11, 2003 | 06:49 PM
Re:injection pump
truck has a pyrometer and the screw was turned 2 times, it go above 1100
tommurray
Feb 23, 2014 10:38 AM
billygoat02
Dec 29, 2005 11:03 PM
adgr71
Nov 28, 2005 07:34 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
cheng
Jun 22, 2004 12:01 PM
