Info center on the fritz!
Old Dec 2, 2007 | 06:07 PM
dieselcarpenter's Avatar
Question Info center on the fritz!
My info lights (brake, wait to start, water in fuel, and ABS) are and have always been on the fritz, when I got the truck I discovered that they didn't work. Found them to unplugged, plugged them in and now the brake and ABS are on all the time, and the water in fuel and wait to start only come on when I hit the starter. Any ideas as to what the problem(s) might be?
Old Dec 3, 2007 | 12:30 AM
Chrisreyn's Avatar
well , teh obvious ( and you 've probably checked this) is to check the ground.
If you look at the wiring diagram,it shows which wire coming from the Info Center is the ground curcuit( IIRC its an orange/white)
Check the wiring to the RWAL at the rear diff and at the valve located on the drivers side frame rail about half way back the bed.
You can also try "resetting" the PCM by disconnecting the battery for about an hour... someone posted that worked for them.
Old Dec 5, 2007 | 01:13 AM
So is it the ground for the whole set of lamps or just the abs? If so does it cause the other lights to malfunction?
Old Dec 5, 2007 | 09:32 AM
Chrisreyn's Avatar
I no longer have teh wiring diagram. It is floating around here somewhere( 91.5 wiring diagram-might be in teh stickey) but if I recall correctly, the ground was for the entire info center plug...and was pin #5 in teh diagram..but it has been about a year since I looked at it....
SORTIE
Jul 20, 2012 01:55 PM
075point9
Mar 12, 2011 08:21 PM
Txwelder
Oct 23, 2009 08:24 PM
klx650a2
Jan 31, 2009 05:14 AM
patdaly
Nov 3, 2008 07:11 AM
