If I run a 4inch lift do i need a drop pitman arm?
Old Aug 6, 2011 | 04:43 AM
clark4020's Avatar
I bout a 4in lift from skyjacker will i have to run a drop pitman arm
Old Aug 6, 2011 | 07:39 AM
BILTIT's Avatar
You will need a steering adjustment of some sort:
Pitman arm, spacer block, , drop drag link or best of all crossover steering.
Old Aug 6, 2011 | 08:45 AM
CaptainChrysler's Avatar
I would say you definitely need to do something. The steering pretty much sucks on these things at stock height, let alone lifted.
The best would be like Biltit said, crossover. With your lift, it should be easy.
Old Aug 6, 2011 | 09:38 AM
clark4020's Avatar
Everyone keeps saying that the steering sucks but my trucks steering is nice and tight ? no slop no play or anything and not rely sure when u say crossover steering would it be good to just get a drop pitman arm?
Old Aug 6, 2011 | 11:05 AM
BILTIT's Avatar
http://offroaddesign.com/catalog/Dana60crossover.htm
http://coloradok5.com/crossoversteering.shtml
http://coloradok5.com/ordcrossover.shtml
Old Aug 6, 2011 | 11:07 AM
BILTIT's Avatar
Listen to what people have to say, we have all learned from experience.
I had a 1980 chev with 6'' lift, first put in a raised steering arm, then a dropped drag link, finally converted to crossover steering.
Wish i would have done the crossover from the start, would have been cheaper and alot nicer to drive.
Is the truck going to see much offroad?
I am currently installing crossover on my dodge with only 1'' lift, just for better steering.
Old Aug 6, 2011 | 02:15 PM
clark4020's Avatar
no not much off roading a sled every now and again and so fields its a farm truck
Old Aug 6, 2011 | 02:54 PM
maxwellp's Avatar
Talking
Originally Posted by clark4020
I bout a IN lift from skyjacker will i have to run a drop pitman arm
Yes put one on, I just put one on my 01 that had been lifted 5" with out the drop pitman arm, It is from Skyjacker, well worth the money. Before the bump steer was so bad I would not let anyone drive it, it would change lanes if you where not ready. Now with the front end geometry back close to how it should be it does not have any bump steer.
exsanguinate
Dec 14, 2009 04:13 PM
Ron R
Sep 16, 2008 11:09 AM
itr.#1446
Jan 2, 2008 04:11 PM
ROADWARRIOR
Sep 4, 2007 05:34 PM
BigDan
Jul 8, 2006 11:04 PM
