Ice cold AC now.
Old Jul 2, 2005 | 06:08 PM
Mudcat's Avatar
Talking Ice cold AC now.
After reading about the evaporator core getting clogged up with trash and such. I decided to take a look see at mine. My gosh it is a wonder it even worked at all. After cutting a hole in the plastic to get to it with a die grinder. I pulled 2 big handfulls out of the box then several smaller amounts. Then got the shop vac in there and sucked the rest out. The fins were still clogged with fine stuff so I got the water hose and a stiff brush and cleaned it all out. Then made a patch panel out of some 16 guage steel put some screws in it and turned it on. I can now get the temps down to 40deg and not have it freeze up plus it blows much harder now too. A well spent afternoon.
Old Jul 2, 2005 | 07:15 PM
pwrtripls1's Avatar
Awsome deal. Too bad mine didnt come with AC. Not a big deal in Maine, but when i get back to Texas it may suck on those 100*+ days.
Old Jul 2, 2005 | 07:25 PM
Den's Avatar
Den
I just took a peek through the vent. It's totally clogged and I get 57 out of the vent and it cycles constantly. I need to do this fix and get some real air going.
It's like 105 in my truck when I get in it in the afternoon. That's with tinted windows and a solar shade in the windshield. Takes the whole trip home to get cooled down.
Den
Old Jul 2, 2005 | 07:31 PM
Mudcat's Avatar
That's the way mine was too. Here are some good instructions that were posted for this.
click here
Old Jul 2, 2005 | 10:03 PM
Micaiahfied's Avatar
on a long trip from NY back to TENN with the a/c i found that on the passenger side by the firewall there was something was had so much condensation that it was actually dripping... any idea what it is... and is it a big problem?
Old Jul 2, 2005 | 11:12 PM
12valve@heart's Avatar
Dripping inside on the floorboards or outside underneath? Outside underneath behind the RF tire is the normal location for the condensation drain. Inside on the floorboards is not normal and may indicate a plugged or disconnected drain line.
Old Jul 2, 2005 | 11:14 PM
well it's not draining in... there is something back there that was getting cold enough to get condensation all over it... enough to eventually drip. i guess it was acting like a dehumidifier in the truck.
Old Jul 3, 2005 | 05:01 PM
Den's Avatar
Den
The dripping out of the intake vent is due to the drain being clogged. Mine has done it numerous times. Usually it comes out the vent on a left turn...on the gf's feet I'm evil
It's under the hood below the evap box. Just roll the tube between your fingers. Don't be suprised when crunchy crud and a TON of water comes out. See photo below
drain location
Well I cracked open the box front.
evap_box
My temps dropped and I was seeing about a 25-28 degree differential between cab temp and vent temp. No more cycling like crazy. Lowest temp I saw was 52 and I got the cab down to 75. It was 102 in the cab when I started. My house AC is set on 78 and it feels cool to me
The fan is blowing some serious air now. The little vent blades were flapping in the breeze.
Now that it's not cycling like mad, maybe I can put part of another can in it.
Den
Old Jul 3, 2005 | 06:06 PM
Big Perm's Avatar
drain location
evap_box
Den
What the hell was all the crap?
I'm going to check mine out now. Mine blows ok, but in Tucson I could use it a bit colder
Old Jul 3, 2005 | 06:37 PM
Den's Avatar
Den
Leaves and pine needles. Looked funky from the flash. Not to mention the crud covering the entire surface of the evap
Den
Old Jul 3, 2005 | 10:22 PM
Blowndodge's Avatar
After thinking over cutting open the front of that box and having to repair it, I think I came up with a decent alternative.
The far right hand side you see in the photos of Den's site a "waffle" grid like structure. The top of the grid is far enough up behind the glove box to be hidden from view.
I took a small fine tooth hacksaw blade and cut the slats on the top two runs of the grid and then took a very flexible vacumm hose (about an inch in diameter and ran it down and to the left where the condenser is. I pulled out a ton of trash and don't have to repair what I cut because its out of view and when you throw the switches for the vents, the hole gets covered completely.
I can't "scrub" the condenser but I got a lot of trash and leaves out of it.
Brad
Old Jul 4, 2005 | 11:28 AM
pwrtripls1's Avatar
Hey, since i dont have an AC how does the defrost pull the moisture out of the air? All i have is floor vents and defrost.
Maybe i will just get a big AC convertor and put a small windo unit for a house in the back window.
Thats not too redneck is it?
Old Jul 4, 2005 | 01:14 PM
With the heater core. It works fine when it's cold enough outside to have the heat on, but it's not too fun when it's about 65 degrees and raining buckets.
Old Jul 4, 2005 | 02:29 PM
pwrtripls1 sadly enough i considered that on another truck i had lol
SOhappy
Jan 3, 2014 06:34 PM
cyawallac
Oct 30, 2011 03:15 PM
getblown5.9
Dec 16, 2005 02:15 AM
Patrick Campbell
32
Jul 7, 2005 11:47 PM
ramlovingvet
Dec 6, 2002 04:30 PM
