I decided to try WMO in my truck and I have two questiones
Old Jul 9, 2008 | 09:38 PM
Onemoparnut's Avatar
maybe the sending unit just went bad
Old Jul 9, 2008 | 09:42 PM
Alwaysworking's Avatar
alwaysonDTR
maybe just some loose wires?
Old Jul 10, 2008 | 03:26 PM
DodgerDoob's Avatar
We have all kinds of the stuff at work. What would be a good filter setup to do a few gallons at a time? Maybe gravity feed.
Old Jul 11, 2008 | 06:54 AM
apwatson50's Avatar
Originally Posted by unixcowboy
Most of the WVO sites I looked at say it will clean EVERYTHING !
Some of TDI drivers reported the same thing you are, but it took a couple of tanks. Never heard of it going nuts on the 1st tank...
Just to be clear, WVO and WMO are NOT the same thing.
WVO: waste vegetable oil
WMO waste motor(engine) oil
I've been running about a 50% mix of WMO for about 5k miles now and have seen no ill effects. Except for a slight blue exhaust haze at mostly cold idle and a little once warmed. Some of it may be due to the injectors also, but most of is the oil.
I do filter the oil through a 12 micron filter before it goes into the tank and then once on the truck I eliminated the stock filter and put together my own dual filter setup with the first filter being a 12 micron fuel/water separator filter and then through a 2 micron filter.
I personally feel that it is a must for fuel pump life to filter to 2 micron's, its probably not needed but it makes me feel better.
Aaron
Old Jul 11, 2008 | 07:23 AM
Power Ram 250 C's Avatar
Would a person have to worry about the black residue used engine oil leaves behind? Does it build up on the inside of the injection pump and other components? That is the only thing I am worried about if I run it.
Old Jul 12, 2008 | 09:38 PM
now that I put a few miles on it the fuel gauge is back to normal. I guess maybe I had it too full or something.
Old Jul 13, 2008 | 03:57 PM
johnny5.9's Avatar
What do you guys think this would do to an 07 d-max? I don't know about the injectors. I have no emissions controls of any kind so that isn't a problem. I have a water separator and remote oil filter inline with a pump to feed them would that be ample filtering? I still don't know, though, the duramax is expensive and the lifeblood of my business. But when I spend $650-$700+ every month it's tempting.
Old Jul 13, 2008 | 04:13 PM
M1Lover's Avatar
Is it me or there something sick and wrong about draining the life fluid from my truck then feeding it back into itself?!?
Man, I have a bunch of waste 15-40 but I'm just having trouble getting myself to pouring it in....... H.
Old Jul 13, 2008 | 04:17 PM
921stgen's Avatar
Johnny5.9 I don't know if the cp3 will handle it because I herd they couldn't handle homemade biodiesel but I don't know I would ask on dieselplace or another duramax site.
Old Jul 13, 2008 | 06:18 PM
big stinky's Avatar
I thought that. BUT I did a bunch of reading and found out that it isnt bad for these bosch pumped cummins. Cummins recommends running a small percentage of wmo per tank. I have been running a gallon to 2 gallons for the last few FULL tanks with barely any effects at all. Just smells a little different. Dont know if its the extra fuel im throwing in the tank or what, but it usually bumps me up about 1-3 mpg depending on my foot.
PADuallyBoy
28
Jan 28, 2009 04:44 PM
Juiced01z06
15
Sep 7, 2008 12:15 PM
bigredBCS
17
Mar 19, 2008 05:58 PM
D.Wiggs
67
Dec 19, 2006 11:39 PM
