hx40 or super 40
Old Nov 23, 2009 | 07:18 PM
2wdcumns247's Avatar
hx40 or super 40
i was thinking about trying to run some more boost and i was wondering if i should get a 40 or super 40 or if you have any other suggestions i would like to run over 50psi if not more
Old Nov 23, 2009 | 07:20 PM
What does boost pressure have to do with anything?
Old Nov 23, 2009 | 07:46 PM
Riflemanusmc's Avatar
Registered user
If you have the pump mods to support a bigger turbo, then run a bigger turbo. Adding higher boost psi does nothing without supporting fuel mods..If what you have now with your mods, is running high EGT's. A bigger flowing turbo will cool it off.
Old Nov 23, 2009 | 10:33 PM
alright thanks
Old Nov 24, 2009 | 01:42 PM
peobryant's Avatar
If all you want is a lot of boost, then stick with your baby H1C. With equal amounts of fuel, the baby H1C will produce a lot more boost than an HX40. If you decide you'd rather have performance, the Super HX40 would be the way to go given those options, however an S300 would be better suited for all out performance.
Old Nov 24, 2009 | 08:05 PM
Registered user
alright thanks
Your Welcome..
Old Nov 24, 2009 | 08:43 PM
so whats the difference between boost #'s and power im kinda confused
Old Nov 24, 2009 | 08:47 PM
14racing's Avatar
I hope your not plannin on runnin 50 pounds with a stock head gasket. More boost doesn't necessarily mean more power. You need more air flow as you will get from a bigger turbo.
Old Nov 24, 2009 | 08:49 PM
no my plan is to do headstuds and my tranny should be done in january but i would like to try and make atleast 500hp i might even do twins and run over 80psi im not sure yet im just trying to get some ideas
Old Nov 24, 2009 | 09:15 PM
W150CTDproject's Avatar
I'd listen to Riflemanusmc, he's a good guy. i sold him my 92 half ton a few weeks ago. He told me to go with the super 40 just because of the fact that it doesnt hurt it if you "bark" the turbo. the shaft is stronger.
Old Nov 24, 2009 | 09:36 PM
what is the turbo bark you are talking about my truck does it all the time now is it bad for it or what does it do
Old Nov 24, 2009 | 09:50 PM
honestly im not sure what turbo bark is but i hear its bad for the HX35 and regular HX40 shafts, maybe some of these other folk could fill us both in on "turbo bark"
Old Nov 25, 2009 | 12:29 AM
Twisted Inc.'s Avatar
ahh lets see if i can explain what they are talking about as far as psi to power......just because your running high boost pressure doesnt mean that your adding as much power as possible what your looking for is high volume of air......for instance installing bigger intercooler tubes will lower your boost pressure but will not hurt your power....because the same if not more volume of air is being pushed into the motor....there for lowering egt's and helping power....i hope that makes it clear as mud for you...
Old Nov 25, 2009 | 01:04 AM
schamran's Avatar
X2. PSI (pressure) is a measure of restriction, not flow.
Old Nov 25, 2009 | 08:30 AM
alright thanks kinda understand you want a bigger turbo for more volume not boost right?
