hx35 a how to? best turbo upgrades for money?
Old Jul 23, 2008 | 03:01 PM
1985cucv's Avatar
Guys ive been reading alot about this hx35 turbo and i want to get one. also i was wondering what the benefits are lower egts and more boost i imagine. Also i wanted to know if it is a direct bolt on to an h1c. i would love to have more boost and power in general. what is the best housing for an automatic? will it bump my exhaust backwards? thanks guys
Old Jul 23, 2008 | 03:05 PM
the best housing for an auto id say with out the egts goin to high would be 16cm. but you have 4.56 gears so you wouldnt need anything smaller than that. definely not. lol
Old Jul 23, 2008 | 05:45 PM
I would just get a compressor kit for your H1C. With the gearing you are running and an automatic, a smaller turbine housing is not going to be helpful.
Old Jul 23, 2008 | 08:18 PM
jcmoyer2004's Avatar
hey guys i was wondering with the hx 35 with the 12cm housing on the non i/c first gens 5 speed what the exhaust sound difference is with 4 inch exhaust (i.e. louder, deeper etc) i know there will be more turbo whistle but will it make the exhaust any different other than that
Old Jul 23, 2008 | 09:44 PM
No, when you are standing next to the tailpipe there is a WOOOSHING noise that you can only get with a hx35.and with the 4 inch exhuaust then you will really hear it. remove the silencer ring and it will really whistle at low rpm. not that bad on the highway though. My dad used to have a 96 with the stock hx35 and its sounded so cool when it was idling. id just stand next to the tailpipe tip and listen.
Old Jul 24, 2008 | 12:22 AM
big stinky's Avatar
Not really any noise difference at low boost, but when the boost gets up there it sounds different. Cant explain it in "type" tho unfortunately.
Old Jul 24, 2008 | 04:55 AM
Hot Dawg's Avatar
Hey Nick, I would just do the 60mm wheel swap on your H1C best bang for the buck. Just my $.02
Old Jul 24, 2008 | 07:13 AM
1985cucv's Avatar
thanks guys for the responses now alls i need is the $$$$$$$$$$$$$$ for all this new found power
Old Jul 24, 2008 | 08:19 AM
1985cucv's Avatar
Where would i find one of these 60 mm for a decent price? thanks guys.
Old Jul 24, 2008 | 12:24 PM
CaptainChrysler's Avatar
Gillette Diesel Service is the best deal.
http://www.gdsdieselparts.com/Home.htm
I would just call and talk to them. Sometimes they are back-ordered, sometimes not. I guess I got lucky, and had mine within days of ordering.
I think they call it a "stage 2", but just ask for a 60mm compressor for an H1C.
Old Jul 24, 2008 | 01:10 PM
1985cucv's Avatar
hard to install?
Old Jul 24, 2008 | 01:23 PM
1985cucv's Avatar
and how much did yours cost??
Old Jul 24, 2008 | 03:23 PM
Mattster's Avatar
Install is easy I have the HTT IV pretty close to the same thing. there is a stick on changing compressor wheels. Takes about an hour to do for the first time. Hardest part if you are changing the backing plate is the 4 little bolts hold the plate on.
Old Jul 24, 2008 | 03:24 PM
As far as installing it, it's very simple. Here's the wrie-up from the sticky. You won't have to mess with the backing plate for a HTT stage III or GDS stage 2 (they are the same thing)
https://www.dieseltruckresource.com/...d.php?t=112422
Got to have a torque wrench that reads "backwards" as compressor nut is LH thread.
Mine was like $180 plus shipping as of last december.
Old Jul 25, 2008 | 07:13 AM
1985cucv's Avatar
yeah i was looking at it and i believe it is 400 bucks or am i looking at the wrong thing. i looked at compressors under dodge stage 3 is 400 thanks guys for the input. also i believe i have the 18.5 exhaust side housing would i need to change anything on this or just run it. the truck scoots pretty good right now with good turbo spool but i imagine it could get better. thanks again
