Hx35 boost
Don,t blame the turbo all the time, you might have a boost leak somewhere, you might not be getting the fuel delivery like you were before, did you notice a loss in power, maybe the gauge is defective, just some thoughts.
Steven M
Steven M
The waist gate is set very low. You should disconnect the waist gate ans see what it does. If the boost increases buy a boost elbow and reconnect the waist gate
Sent from my Transformer Prime TF201 using Tapatalk 2
That must be the problem, because I can hit 35 Psi with mine and it has the boost elbow in it.
I upgraded to a super B, now 15psi feels like 35 did on my HX35. Having used both I personally believe the efficiency of the HX35 drops upwards of 25psi. It probably gets a bit more but I think it's mostly noise and our imagination at that point.
My boost goes up as I give it fuel.Had lil ove 20 lbs turned in fuel screw got about 28 lbs.Then I ground my fuel pin a lil and now I run 35 lbs @WFO
I'll leave it there,truck runs strong with stock inj. and EGT's require me to watch close now when pullin hard.
xloudnproud
22
Apr 27, 2006 11:41 AM
Jambbii
Dec 23, 2004 12:20 AM
ClawHammer
Aug 7, 2004 08:49 AM
Captain Insane-O
Jan 11, 2004 03:08 PM
