HX-35 or HX-40
Old Jan 25, 2009 | 05:12 PM
BurrisWill's Avatar
HX-35 or HX-40
Whats your opinion on one of these turbos on a first generation. Anybody running them on their truck? Is there any difference in installation
Old Jan 25, 2009 | 06:28 PM
Hx40 has a 4 inch exhaust oulet
hx35 has a 3 inch exhaust outlet just like your stock h1c
so a 4inch downpipe will be needed.
a hx40 is a nice upgrade, as long as it has the 16cm housing and not the 18cm its pretty much an awesome upgrade. it has a 60mm comrpessor wheel compared to the hx35's 56mm and the H1C's 56mm. Bigger exhaust outlet.
Old Jan 25, 2009 | 07:32 PM
peobryant's Avatar
An HX35 is a good upgrade for a non I/C truck with the "baby" H1C, bt if its an intercooled truck, it's not worth the effort.
HX40's are pretty good turbos, but they do not like to be barked at all. They share the same shaft as an HX35, and barking will cause the shaft to break.
Old Jan 25, 2009 | 08:13 PM
BurrisWill's Avatar
When you got your denny t pen, did you turn anything up on the injector pump or mess with the star wheel any?
Old Jan 25, 2009 | 08:23 PM
peobryant's Avatar
No, I didn't mess with anything else.
Old Jan 25, 2009 | 08:52 PM
It's time
more words
Old Jan 25, 2009 | 10:03 PM
peobryant's Avatar
It's time
more words
I still have stock injectors, so I won't be messing with the fuel screw. I have a 16cm housing on the way, but that's all I really plan on doing for a little while. I need 6 new tires, and I have to get those before I can do anything else. Then a stout tranny. Then the fuel mods.
Old Jan 26, 2009 | 10:12 AM
BurrisWill's Avatar
I got u thats smart. Im trying to ressurrect the one i got
Old Jan 26, 2009 | 03:47 PM
peobryant's Avatar
That's what I'm trying to avoid. I'm only planning to make 350rwhp so it should still be very reliable.
Old Jan 26, 2009 | 08:29 PM
Alwaysworking's Avatar
alwaysonDTR
315Hp seams to be reliable so i dont 350 is out of reach
maybe if i had a good lift pump i'd be there
Old Jan 26, 2009 | 11:17 PM
peobryant's Avatar
When my brothers '97 was right around 350rwhp, it was very reliable. He towed our parents boat with it numerous times, and hauled farm equipment so I have no doubt in my mind that 350rwhp is reliable. I'm taking all the steps beforehand, to make sure all the tings that might go wrong, get fixed, so they won't go wrong.
Old Jan 27, 2009 | 01:02 AM
kensmachine's Avatar
91 1st Gen what is barking. ken
Old Jan 27, 2009 | 11:01 AM
CONFEDERATESON's Avatar
thanks for asking ken i had the same q. please shed some light-also what psi can be expected with the 35 and 40??? THANKS, Ryan
Old Jan 27, 2009 | 11:44 AM
dstad's Avatar
hx 40 will get u a lot of smoke and a lot of power if you have the fuel to spin it. i thinking about one
Old Jan 27, 2009 | 04:22 PM
Barking is when you let off the accelerator suddenly under boost. The turbo will make a "woofwoofwoof" sound. It's bad because you are stalling the compressor, it puts a lot of strain on the turbo shaft. Repeated barking will break a '40 because it uses the same diameter shaft as a '35 but it has a larger (and much heavier at 40,000 RPM) turbine wheel.
Boost depends on fuel.
