httstage3 vrs httstage5
Old Oct 23, 2006 | 07:01 PM
keithplacervill's Avatar
is there a diff between the two besides sound i mean performance and cooling side of things and if so is it worth the 100.00 diff in price
Old Oct 23, 2006 | 07:10 PM
gman07's Avatar
I think you mean the Stage III and Stage IV - I talked to Paul at HTT before buying my Stage IV, and he said the IV would cool slightly better than the III because of the bigger exducer. They should sound about the same.
Old Oct 23, 2006 | 07:14 PM
so it sounds like the stage 5 is not worth the extra 100.00 for me sound like they are about the same does the stage 3 also have a 6 blade
Old Oct 23, 2006 | 07:26 PM
gman07's Avatar
The Stage 3 is an 8-blade design.
Old Oct 23, 2006 | 07:30 PM
Iam slow is the 8 better than 6 or is 6 better than 8 or does it matter
Old Oct 23, 2006 | 07:40 PM
gman07's Avatar
Well, in this case 6 is better than 8. I don't know the specifics of why, except that the 6 blade wheel on the Stage 4 has a larger exducer (the big side of the wheel is 86(?)mm instead of 83(?))
Old Oct 23, 2006 | 11:53 PM
Micaiahfied's Avatar
i would take a stab that the 6blade is better because less weight when you are spinning something that fast is a positive. but if the exducer is larger they may even out. if it's the same rotational inertia then spool should be the same (right? lol) from what i hear the stage IV flows 10% more.
Old Oct 24, 2006 | 06:11 AM
JD730's Avatar
This is why when you buy a stage IV they have a backplate that has been bored out bigger to take the stage IV wheel. If you can do it your self on a lathe then just ask for the proper dimensions.
Old Oct 24, 2006 | 11:02 AM
A-Poc's Avatar
To my knowledge, blades on a turbo work the same as blades on a propellor of a boat. The fewer the blades, the more efficient the airflow will be but having more blades also illiminates wobble under load. The actual blade design itself needs to be calculated into the equation as well.
A turbocharger turns wicked rpm so the amount of blades or lack there of, can be very critical to the performance you desire.
Keep in mind this is taking my knowledge from boating and applying it to turbochargers.
Hope this helps,
Mike
Old Oct 24, 2006 | 01:32 PM
johnny5.9's Avatar
Talking
I would think that trim would be more importnat than the number of blades. Trim being the relationship between the inducer and exducer diameters. Assumin all else remains the same, the larger the trim the more airflow. However as wheel size goes up efficiency goes down. The idea is to increase trim without increasing the overall wheel diameter. TRIM=(MINOR/MAJOR) squared x 100
The compressor side of the turbo isn't really responsible for spool-up times either, so you don't need to be concerned with that factor. Turbo lag comes from the turbine side not be able to efficiently accelerate the shaft. Compressor choice affects the temperature at which the air is expelled and thus its density. Hope this helps.
sawboywv1
15
Jul 11, 2004 10:11 AM
sawboywv1
Dec 24, 2003 01:32 PM
Mopar_Mudder
16
Jun 28, 2003 12:50 PM
Mopar_Mudder
30
Feb 17, 2003 04:18 PM
Mopar_Mudder
Nov 5, 2002 10:40 PM
