Htt Stg3 Vs Stg4
Htt Stg3 Vs Stg4
Is it worth the ex hundred bucks ? I've got a HX40 and a 2nd gen 4in dp, and the turbo only needs a new comp wheel priced for 130 bucks from HTT .So which do I put on the htt kit , or put on the HX40 with a new comp wheel ?
You don't have enough fuel for the HX40 yet. Since you have a HX40 sitting around, I wouldn't spend the money for the Stage IV. When you outgrow the Stage III you can put the HX40 on.
It needs a new backing plate because the exducer on the compressor wheel on the stage 4 is bigger. The new backing plate has been machined to fit the bigger wheel. Also, the inducer on the stage 4 is a 6 blade vs. 8 blade of the stage 3. it's supposedly more efficient.
Not really. I have a Stage IV and I wish I'd saved the money for a bigger turbo. It's not that it's a bad turbo, it's just that I simply have too much fuel for it.
For a guy with stock injectors or 190's, a hybrid is fine. For a play truck on a budget, POD's and a hybrid are fine - just don't try to use all that power to tow a fiver up a mountain.
How is that 2nd gen downpipe going to fit? I just put one of Rip's 4" 1st gen downpipes in on a HTB2, had to cut 5/8" to move it forward alittle more, tight, but isn't hitting/rubbing anything.
Dave, how big are you thinking?
not really looking to make big power because it's my daily driver and I tow my race truck with it but I did pick up some isspro gauges from a friend yesterday for free and I hooked up the boost gauge at wot it's making 36psi of boost in over drive it seems high for the little h1c what do you think?
i was woanering if i should go with the stage 3 or 4 i am planning to have my pump rebiult here quickly and wandered if it would be a good idea to put a 3200 ogv spring in and a smaller exhaust housing on too? i was going to have the pump shop do some tweekink on it, the guy told me he could make the first gens run pretty waspy, but i was wandering if the fuel mods with air would allow me to still pull simi heavy loads with a safe egt
well my probe is after the turbo, i plan to move it to the manifold, i had put it there from working on trucks and tractors, but on occasions (before my pump started to leak) i would see an 850* would you think i have a 21cm housing with almost a 4 sec spool up when floored
