How to turn truck to stock???
Old Aug 16, 2010 | 03:32 PM
CTram250's Avatar
Hi, I own a 89 W250 that I plan on hauling my tractor that is weighted to 7500 lbs with. The last person who owned the truck had turned the pump up quiet a bit. i already have put the AFC control back to stock, but I was wondering what else the owner might have done to it and what I have to do to turn it back to stock. The truck runs great, but it gets awful hot, awful quick....Thanks
-CTram250
Old Aug 16, 2010 | 03:54 PM
Onemoparnut's Avatar
How hot is awful hot? Do you have a pyrometer?
Old Aug 16, 2010 | 04:41 PM
blackfordd's Avatar
More fuel = more heat. Power screw may be tampered with.
Old Aug 16, 2010 | 05:01 PM
CTram250's Avatar
Im pretty sure that he did mess with the power screw on the pump. I usually let off when the pyro says 1200 but if i dont it will keep climbing. I never towed anything to heavy with it, just a few garden tractors amd a smaller ford tractor. I just dont want to burn it up with the heavy one behind it... Which one is the power screw? And how exactly do i turn it down?
Old Aug 16, 2010 | 05:35 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
"power screw adjustment".... id probably turn it back until just before idle doesnt seem smooth anymore. you just need to loosen the 13mm jam nut and then turn the power screw counterclockwise.
Old Aug 16, 2010 | 10:11 PM
CTram250's Avatar
Ok, thank you guys for the information, just a few more quick questions, how much boost should a stock truck be putting out? And what would be the average egts be for a stock truck. The way it sits now, it will peg
my 30 pound boost gaudge and keep it pegged untill I let off.
Old Aug 17, 2010 | 01:40 AM
Crazy Matt's Avatar
Should just upgrade ur turbo/ exhaust rather then detune it.
I know I enjoy the extra power when towing my antique tractors
Old Aug 17, 2010 | 06:30 AM
SORTIE's Avatar
don't run your truck with EGTs > 1,200F for very long
Old Aug 17, 2010 | 02:24 PM
CTram250's Avatar
Yea, i have a turbo off of a 06 that i plan on dropping in there, but i need a little bit more cash to put it in the truck. I have a 4 inch aftrer the downpipe with a banks muffler in it. I am waiting for the extra money before i do the turbo and the downpipe. Thank you for the replys, i think i am going to turn it down tonight, ill let you guys know how the boost and egs are. Thanks again
Old Aug 17, 2010 | 09:43 PM
CTram250's Avatar
Well, Now i turned the power screw down on the pump about a turn and a half. I turned it down just about as far as i can go without turning the idle up on the truck. i turned the plastic wheel unnderneith the fuel pin up 1 turn (It was burried to the bottom) and i out the AFC back to stock. When I hit the truck hard coming up the road it still put out 25 pounds of boost and 1200* temps. Should I turn up the idle and keep going with the power screw or try something else? Thanks,
-CTram250
Old Aug 18, 2010 | 05:21 AM
youll probably need to mess with idle screw and keep turning out the power screw to get it where you want it.
Old Aug 18, 2010 | 08:54 AM
blackfordd's Avatar
Yeah, bringing out the power screw is gonna be less fuel so you are going to have to turn up the idle. That seems to be what you are looking for.
Old Aug 18, 2010 | 10:58 AM
huntinguy's Avatar
First time I ever heard of someone wanting to turn there truck down. LOL
blueghost08
Jul 26, 2011 12:25 PM
cheadlesram2500
19
Jan 14, 2009 09:39 PM
stealman1
Nov 9, 2007 11:07 AM
expressfish
18
Mar 11, 2007 04:28 PM
