How the Speedometer Sending Assembly works
Old Jan 20, 2010 | 07:40 PM
shawnm1979's Avatar
I just did a complete driveline swap into my '93 2500. How can I get my NP203 to drive my spedometer? I have a 2wd auto trans left over from the swap. Can I remove the speedo guts and move them into the 203?
Old Jan 21, 2010 | 11:56 AM
Chrisreyn's Avatar
Shawn, if your asking that to me, well, sorry , thats a bit beyond my knowledge base!
Ya might check with some of the guys here who rebuild tranny's, they should be able to help ya.
Old Jan 21, 2010 | 01:30 PM
ofcmarc's Avatar
If the drive adapter/vss will thread on to the 203 speedo drive it should work. You may have to find a different ratio box to correct the speedo if it is off though.
Old Aug 24, 2010 | 09:31 PM
davis1204's Avatar
I have almost completed a swap of a '93 cummins into an '85 crew cab. The donor cummins truck was two wheel drive with a three prong speed sensor. I had a 4x4 overdrive put together and am going to run the NP205 t-case out of the crew. The crew was originally cable driven, so it has the ratio reducer shown in Bookshelf's photo. How can I get from the reducer to a three prong sensor?
Old Aug 25, 2010 | 07:31 PM
The VSS screws on where the speedo cable wouldgo.
Old Aug 26, 2010 | 11:39 AM
davis1204's Avatar
Sorry, I forgot to mention that the '93 sensor has a built in ratio reducer and will not fit the t-case. Therefore, I can not just screw the '93 onto the reducer and can not replace what is in the t-case with what is on the '93. The '92 and previous will screw on but are only two prong.
Old Aug 26, 2010 | 03:38 PM
james1's Avatar
Question grease fitting?
Wanna and other with 2WD trucks have reported having a grease fitting ("zerk" or "alemite") on the gear ratio reducer. The gear ratio reducer on my 4WD doesn't seem to have one. Can anyone comment on which units came with a grease fitting and which did not?
TIA
Old Jul 21, 2014 | 07:26 PM
jcmoyer2004's Avatar
I hate to open this thread up again but I'm stumped. I have a 91 d350 auto and my speedo stopped working and it stopped going into OD. I figured it was the VSS and bought one from oreilly. I got home and noticed that I don't have a gear reducer on mine so I just replaced the old one with the newer one.
The new one came with a new wiring pigtail but there were no other plugs that I could see on my stock wiring to plug the other end of the pigtail into so I just used my old wiring and plug. Took the truck out and still the speedo doesn't work and it won't go into OD.
Could I have gotten another bad VSS? Is there anything else I can do to fix this? I'm getting pretty aggravate with this truck lol
taylorjr94
Jan 22, 2015 06:39 PM
Montana2x2
Jul 5, 2011 07:50 PM
Adam8361
Mar 10, 2010 10:24 AM
Bigdenny
19
Feb 24, 2007 07:08 AM
Bigdenny
Nov 24, 2006 08:40 AM
