How To--Recharge my Air Conditioner
Old Jul 1, 2011 | 08:43 AM
  #31
maybe368's Avatar
Originally Posted by purecountry49
Well, getting back to the repair of the A/C in my truck. The local dealer who stated they could get me a clutch fell thru. But, I e-mailed several e-bay sellers whom advertised the compressor/clutch and a seller sold me just a clutch for the compressor. I had hoped this thing would be blowing cold air by now, but, all takes time if you want to save your hard earned dollars. Going to try and get it installed today, hopefully. Not a lot of auto repair shops can help when you tell them you want to keep the R-12. They are just not set-up for R-12 anymore.
Found a local upholstery shop to replace my headliner for an amazingly low price (I thought) of $65.00. It looks great!!!
Thanks Up Front
Will
You should be able to install it yourself, the clutch is an easy install and only requires removal of the serp belt...Mark
Old Jul 1, 2011 | 03:48 PM
  #32
purecountry49's Avatar
WELL, help is probably the word that is most fitting currently.
Took my belt off and turned the compressor it sounds/feels rough as if it has a grinding wheel inside. I suppose after about 7 yrs of not being used it will condensate and rust on the inside??? Any thoughts??
Thanks Up Front
Will
Old Jul 1, 2011 | 05:21 PM
  #33
maybe368's Avatar
Thanks Up Front
Will
I am not sure what it should sound or feel like, but I am pretty sure that it should not feel like a grinding wheel. Sounds like the compressor is bad, but not 100% sure...Mark
Old Jul 1, 2011 | 08:41 PM
  #34
whosdunit's Avatar
My 91.5 d250 has the old r-12 conn. but the po.,had a new comp., put on , noone knows if it has 134 or r12, or freeze 12!!! Is there a way to look at the oil and tell which is wich??? The parts house said i have to be licened to buy freeze-12!!Will it mix w/ r-12? it still has some pressure in the system, but not enough to run the system.
Old Jul 8, 2011 | 08:12 AM
  #35
Saga continues
Well my problems have not been resolved yet.
My A/C hasn't worked for yrs. When I 1st wanted to check it and fix it the low side would not and still will not give me a pressure reading. I tapped on the schrader valve and there is pressure and the clutch has voltage to it. Clutch is bad, so I have found a clutch which the A/C mechanic said then was all I needed. Well, last Friday when I went to have them put the clutch on they said when they turned the compressor it felt rough and maybe I should go ahead and buy a new compressor. After so long a period of time not working would it be a normal condition for the compressor to be hard to turn or feel rough. And my thoughts are what is the problem with not being able to get a reading at the low side. Is the schrader valve bad or is there a blockage in the system?
How would I be able to evacuate the system and save the R-12 (in what container)? No one I have talked to in the industry has facilities to capture R-12.
Thanks Up Front
Will
Old Jul 8, 2011 | 10:20 AM
  #36
maybe368's Avatar
Thanks Up Front
Will
Strange, that is required by federal law. Every one of them here has a recovery system and they are not cheap. There are people here that went to all the wrecking yards and recovered all the old R-12...Mark
Santaclaus
Mar 19, 2011 06:06 AM
fireram
Jul 18, 2008 07:07 PM
ozzie
Sep 29, 2004 08:50 PM
