How often are you changing fuel filters?
Old Jan 5, 2017 | 06:16 PM
N. Besonderes's Avatar
10 Year Member
I put about 600 miles per week on my rig which means I'm changing oil and filter every two months. I do it when the odometer hits an increment of 5,000. I've been kind of just blindly draining and changing the fuel filter, not really paying much mind to it. I guess I need to get a fuel pressure gauge.
-Niemand
Old Jan 5, 2017 | 06:21 PM
ofelas's Avatar
summit 20psi gauge + tapped banjo bolt are approx $20 total.
or isspro lit gauge for $50 more underhood bling :-)
Peace of mind. Short grease gun hose with male to female coupler almost eliminates needle swings and saves gauge.
$25 fuel snubbers not as effective as grease gun hose.
Needle valve to eliminate gauge bounce unreliable long term.
Old Jan 5, 2017 | 07:11 PM
1972RedNeck's Avatar
How does the grease gun hose help? Just the bigger diameter lets it hold a lot more fuel than a 1/16" plastic line? What it the male to female coupler for? Are we just talking a normal pipe coupler to make the connection or a special grease coupler?
Old Jan 5, 2017 | 07:22 PM
ofelas's Avatar
Dampening by virtue of length. NOT a pun.
normal npt coupler to adapt male hose end to male gauge end.
sorry that was meant to be typed as female to female coupler joining 2 male ends
again, not a pun
Old Jan 6, 2017 | 06:28 AM
KRB's Avatar
KRB
I'm using the grease gun hose and a Westach gauge. Normal psi is about 9 for me.
Old Jan 6, 2017 | 03:30 PM
u2slow's Avatar
I run a primary Racor ahead of the lift pump. It has the clear lower bowl i can monitor and drain off water as needed. I change that fuel filter every 2nd oil change since I'm often burning off old furnace oil or WMO blend.
I changed the stock fuel filter on the engine to one with a closed bottom. Haven't decided on a specific interval.
Old Jan 8, 2017 | 01:20 AM
I run the cheap G2 fram clear inline filter between the tank and lift pump....I change this one about every 6 months. I like the clear because I can see the gunge that builds up. I usually change the big fuel filter once a year.
But if I was to install the fuel pressure gauge set-up as suggested above....I probably could go longer between big fuel filter changes.
CUM4X4MINS
41
Nov 20, 2007 11:15 AM
sakisaki400
56
May 31, 2007 11:12 PM
t-boe
39
Apr 21, 2007 10:52 AM
1stTimeAround
26
Jul 10, 2006 11:56 AM
OH Sick
Dec 17, 2002 04:42 PM
