How much is too much?
How much does the left side of your truck sag? Mine sags 1 1/2" on the left rear and 1/2" on the left front? Is that about normal? Would new shocks correct this? Or do I need new springs? I know it's going to sag some, but what's "normal"?
There was a Dodge service bulletin that deals with a left side low problem.
Service bulletin says to install a spacer on the left front spring.
Spring Spacer, PN 4322629 adds 1 inch of height
I've put the coil spring spacers in the front, the ones you get from the auto parts stores for about $20. They raised the front end some (probably back to stock). I don't think a busted shock would cause it to sag that much, do you? They're not really supporting much weight.
I have the same issue with huge shagg on the left side, I went throu napa for mine they were made by a company called triangle? Even tho there 300 a piece it was well worth em very heavy duty and made the truck almost level again hope that helps
jjrightmire1973
Nov 20, 2008 08:20 AM
