How does the M&H Timing Spacer work??
Old Jun 12, 2010 | 09:12 PM
  #91
jimbo486's Avatar
awesome info! way to go KD!!
Old Jun 12, 2010 | 11:36 PM
  #92
JustRamIt91's Avatar
THANK YOU! I was unsure if the actuation of the lever was directly correlated to the * of timing, as moving the pump would be, in the same amount of distance.
Old Jun 22, 2010 | 07:42 PM
  #93
jimbo486's Avatar
for anyone planning on installing a spacer, be sure you clean the screws well! i came pretty close to stripping one of mine out. i decided to take a pick of some sort and clean the screws of all dirt and grime that had built up over the years. the result, the torx bit was able to sit deeper inside the head of the screw and not slip out.
Old Jun 22, 2010 | 09:43 PM
  #94
Onemoparnut's Avatar
Well hows it run? Does it make a big difference?
Old Jun 22, 2010 | 10:22 PM
  #95
i'm interested
Old Jun 22, 2010 | 10:26 PM
  #96
The_Head's Avatar
I towed with it. 7200 lb travel trailer up the mountain one time. 4500 lb carhauler with car up and down the mountain the other time.
Truck ran good, nothing blew up. 80+ down the interstate towing the car too!
Old Jun 22, 2010 | 10:28 PM
  #97
what would you say changed before and after, did you make any other adjustments?
Old Jun 23, 2010 | 12:01 AM
  #98
jimbo486's Avatar
top end response is the most noticeable difference by the seat of my pants. i've seen a drop in EGTs of about 200 degrees.
Old Jun 23, 2010 | 09:42 AM
  #99
cougar's Avatar
For some reason I've lost ground. Lost a third of my boost from 30 down to 20 and a corresponding loss of power. It did lower my EGTs though.
Old Jun 23, 2010 | 12:16 PM
  #100
The_Head's Avatar
I thought advancing the timing would lower your boost pressure a little? 10 psi is a bit much though.
Old Jun 23, 2010 | 12:19 PM
  #101
jimbo486's Avatar
i haven't seen a loss in boost pressure on mine.
Old Jun 23, 2010 | 01:58 PM
  #102
Cougar; Sounds like your too advanced for your own good, maybe its time to get a little retarded.
Old Aug 2, 2010 | 10:03 PM
  #103
schamran's Avatar
So can my truck handle 37 degrees of timing? rephrase: can my truck benefit from 37 degrees of timing?
Old Aug 2, 2010 | 10:58 PM
  #104
MoPowa's Avatar
hahahaha! I'm hoping to get a little retarded when they get some more of these spacers available.
Old Aug 3, 2010 | 01:23 PM
  #105
QIK2D's Avatar
how will this affect cold weather starts when the ksb is activated? i like the idea of that much advance when driving but if it sacrifices freezing start ability i can't do it.
daryl
