How does the M&H Timing Spacer work??
Old Jun 7, 2010 | 04:58 PM
  #46
jimbo486's Avatar
it's just a matter of removing the 2 bolts holding the KSB on and the pressure regulator and line that feeds the KSB. M&H supplies longer bolts and new o-ring. place the advance piston spring and shim back in the pump, spacer between the KSB and housing.. bolt it back up and install the regulator and line!
Old Jun 7, 2010 | 05:24 PM
  #47
KD93's Avatar
Originally Posted by blackfordd
... but I believe that bumping the pump for more timing with the spacer is an option too.
That's what I was getting at, in my roundabout convoluted way.
Old Jun 7, 2010 | 08:00 PM
  #48
JustRamIt91's Avatar
From what i understand after reading this entire thing.... two times at some points...
This KSB works like the vacuum advance on your gasser distributor, it advanced the ignition timing depending on rpm or load. Except this works differently because there is no vacuum on a diesel.
This mod allows the advance mechnism to move more than stock, 6.4mm, as the rpms climb. As opposed to the stock 2.4mm allowed travel.
SO...No matter where the IP is positioned this will allow more timing advance.
This seems like the compliment to the 3200gsk spring. Now throw a fuel pin on top of it all...watch out tires, you don't stand a chance.
Old Jun 7, 2010 | 08:18 PM
  #49
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
how does the 2.4mm or 6.4mm of advance convert into degrees of timing?
Old Jun 7, 2010 | 08:32 PM
  #50
This is a good question...
Old Jun 8, 2010 | 09:27 AM
  #51
ebteckx's Avatar
The more I look at this piece the more I want to try it. Does the regulator line need to be horrible bent to get it to install with the new spacer? Either way this seems to be a great upgrade as long as the piston cant move too far and get stuck. Actually I cant really see that happening... I think I have added this to my wish list..
Old Jun 8, 2010 | 10:43 AM
  #52
HDBeauty's Avatar
I would like one also...What is their website address?
Old Jun 8, 2010 | 10:56 AM
  #53
KD93's Avatar
This thread may or may not answer your ? https://www.dieseltruckresource.com/...timing+degrees
From what I've read, a tooth is equivalent to an 1/8". 72 teeth on the pump gear, so 1/8" = 10°. I just checked online and 2.4mm = 1/8", (well, not EXACTLY but pretty darned close.) Therefore, 2.4mm = 10° timing. Confused yet?!
Last edited by KD93; Jun 8, 2010 at 11:07 AM. Reason: Attempting to muddy up the answer!
Old Jun 8, 2010 | 01:16 PM
  #54
Www.mandhinc.net
Old Jun 8, 2010 | 06:04 PM
  #55
Well i forgot to do a writeup with pics but heres the best i can do...
http://www.cumminsforum.com/forum/89...ml#post3054641
Old Jun 8, 2010 | 07:32 PM
  #56
jimbo486's Avatar
i probably know the answer to this question but when pulling the KSB, does the fuel drain out of the pump??
Old Jun 8, 2010 | 07:35 PM
  #57
when i pulled one of the bolts (the one nearest the cab) some came out but not much. i dont know how much is in the pump but i bet only 1/8 cup or less came out. the truck started up as it normally would when i first fired it up.
Old Jun 8, 2010 | 09:34 PM
  #58
jesussaves's Avatar
HOW ABOUT Getting together and see if we can do a GROUP BUY and get a discount???
Old Jun 8, 2010 | 09:39 PM
  #59
ebteckx's Avatar
Lol I doubt it. The guy is in business but who knows. I sent him an email today Im interested in that M3 and the timing spacer. Looks like a great deal.
Old Jun 8, 2010 | 09:44 PM
  #60
jesussaves's Avatar
here is my write up with pics
http://www.mandhinc.net/DPD-3-D-I.html
