How To Adjust Timing??
Most people do a 1/8 bump, and it supposedly helps with fuel mileage. With the bump you should see more power on the top end, but less in the low range.
You need an "S" wrench though. You can either make one, or Snap-On has one for $33. Here is a link.
http://buy1.snapon.com/catalog/item....&group_ID=1288
Its in the sticky. You need an S wrench like 91 1st gen said. oh... and a ratchet strap and a 4x4 block of wood.
It works good, saw a little bit more throttle response too. 1/8 of an inch past the factory scratch mark is good for some noticable differences.
Try this.
https://www.dieseltruckresource.com/...50&postcount=5
This is link to "STICKY"
https://www.dieseltruckresource.com/...d.php?t=102027
Bump the Timing.
tmacie
Nov 14, 2005 08:54 PM
WildBill
May 7, 2005 09:53 PM
