Horn
Old Jul 29, 2023 | 10:50 AM
Cowboytrader21's Avatar
Horn
1991 Dodge W250. I read there is two horns, a high note and a low note. I have only one horn and there is a wire coming off of it that's tied off and not hooked to anything. The horn in this truck has never worked in the 21 years I've owned it. Do I need to get another horn and hook it up correctly to get the horn to work? I want to get the horn working as well as the cruise control.
Old Jul 29, 2023 | 12:13 PM
With the horn AND the cruise not working, I would suspect the clock spring in the steering column might be a place to look for the problem.
Old Jul 29, 2023 | 12:22 PM
The horn will work with just one horn hooked up, IF the horn works itself.
You can hot wire the horn to see if it works. Then proceed from there.
Old Jul 29, 2023 | 05:37 PM
Fordzilla's Avatar
And a test light will tell you if current exists at the horn when the button is pushed......Ben
Old Jul 30, 2023 | 06:37 AM
Just two of the various ways to "skin the cat".
Old Jul 30, 2023 | 02:52 PM
edwinsmith's Avatar
If you skinned a cat it would make a good horn. 9 times at least.
VaultRam
Jan 6, 2008 01:48 PM
bazdad
0
Sep 6, 2007 11:11 PM
mw06
May 13, 2007 06:30 PM
PEAKSTRYDE
18
Jan 17, 2006 11:58 PM
