Holset he351 VGT theory
Just curious, if the Holset he351 VGT can vary the effective exhaust turbine volume why not put a really agressive compressor section on?
Or bigger. I'm thinking with a good sized compressor wheel and a VGT we might be able to have a single turbo that performes as well as a staged setup.
HAHAHAHAHAHAHAHAHA
Nice idea, but having ran a HE551V, there's absolutely no way you could put it on a 351 frame. That wheel's Major diameter is almost as big as an S480's...
HE551V, with electronic controllers they have coming to market now, might be a viable option...but I couldn't get it to spool below 2000RPM with a ported head and cam, but she made good power once it lit. 551/1083.
Chris
Chris
i had the exact same idea, it just seemed to me that the bigger turbos also had a larger center section. This to me meant (to me) that the interchange was impossible, but with the right adapter plate or maybe have some machine work done, it could be do-able. Having my he351cw to reference, it just a simple flat surface with a stepped groove around the edge, to make that surface larger and have a new groove machined in wouldn't be hard (by someone with the tools). I also think there would be lots of turbo lag, even with it closed.
You may be onto something here, keep looking into it. I'm interested!!
I VE truck better just leave HE551 on the bench...no offense, but if you can't spool it early, it won't work well on a VE. In my experience at least.
If I wanted to modify my 2010, I have a HE551VE, that would swap right on, and plug in and be controlled just like factory. I also think that with a good cam, and the 6.7L displacement, I could spool it very well and make a LOT of power with it...but my 2010 is my daily driver, and I need it to reliably tow in excess of 30K gross weight. High power is not an option...she may just stay stock
Chris
