Hey everybody!
Old Feb 17, 2007 | 06:56 PM
dtherren's Avatar
Hey everybody!
I have an 82 D150. Its not a diesel, but I thought charging systems might be the same.
I have replace alternator, regulator, and ceramic resistor 3 times. Its over charging. 16 at an idle, and 19 a 2000 rpm.
As it turns out (after talking to a mechanic) on these dang Dodges, if you replace a regulator you also have to replace he resistor. Both are externally mounted.
I did that. I also found a couple wires that had been seriously heated and melted the insulation. I cut and replace them.
Now? After about 8 hours not driving, my battery is drained and it wont start. I have trouble getting a good connection on the battery post's with cables. I have to put the negative onto the engine block to get a good connection to jump off of.
I put an ohm meter on it and tested the system. I am getting a reading (with key off) from + battery post to engine, frame, and firewall of 13. Same as between the two battery post's.
I pulled the fuses one at a time, with no change on reading except one of the extra blocks in the fuse box. It went from a 13 to a 7 when I pulled the stereo memory lead from it.
Is this a ground problem and maybe a short problem? Other than replace the harness (its too dang cold out now to do it) or trace out each section to see if I have a shorted wire, the only thing else I know to do is put a battery disconnect switch in.
The alternator is still over charging, but it isnt blowing regulators everyday!
Thanks.
Old Feb 17, 2007 | 07:02 PM
Run a ground wire from the regulator to the engine.
Old Feb 18, 2007 | 01:14 PM
Winr's Avatar
Voltage is not your main concern. Its the amount of Amps it is drawing.
Old Feb 18, 2007 | 03:29 PM
BBrown's Avatar
hey everybody - more charging trouble
"I have trouble getting a good connection on the battery post's with cables. I have to put the negative onto the engine block to get a good connection to jump off of."
This should be your first clue. Check/replace your battery ground cable, and your engine to ground. If the alternater can't "see" the battery it will put out full charge voltage.
One thing at a time and you will track it down. Good luck.
prairie pirate
Introductions / New People
Jan 18, 2009 10:26 AM
98rambaby
Jun 26, 2008 12:23 PM
senior
Apr 3, 2008 10:47 AM
Tnap
Apr 2, 2008 08:35 PM
CB_Parker
Jun 28, 2004 10:55 PM
