Help!!! Water In Oil!!!
I'm guessing if you replaced the head gasket your a pretty good mechanic. My guess is the head gasket either is not sealed tight, the headgasket was bad to begin with, the head is cracked, or the head was warped and the machine shop did not see it
Thats what i am thinking. I think that head studs need torqued back down again... Just torque them back down again and if that doesn't fix your problem you might need to pull your head again.
would it only leak under pressure or would it constantly leak? i filled up the rad. and it keeps leaking down probobly about a gallon every 3 hours. Should i torque them to 66 + 90 deg.?
thanks
Anthony
thanks
Anthony
I thought the torque was 89 lbs/ft + 90 degrees?
I may be wrong. And head studs are a whole different ball of wax. The company just gives you a total torque to crank them to.
HTH
Glenn
HTH
Glenn
4320Diesel
Apr 25, 2011 09:50 PM
Gene Peterson
Jan 7, 2006 02:32 PM
SmokinDodge12V
Dec 1, 2002 08:44 PM
. I had the head checked at the machine shop
