help, truck wont shut off
Ok so today I installed a DennyT stage 2 fuel pin, everything went fine. Truck fired up turned off no problem, went for a drive gave it some pedal came home. I took the fuel pin out to check for travel and wear, put some grease on it and put it back in and turned the smoke screw clockwise a turn. Went to drive for a few minutes, gave it some pedal a couple times and made my way back home. I go to shut the ignition off and it just keeps idling.......I have to manually shut if off now
. I checked the fuel pin and any connections around the pump and everything seems fine.
Anyone have any idea what I messed up????
. I checked the fuel pin and any connections around the pump and everything seems fine.Anyone have any idea what I messed up????
Appearantly all that extra fuel can tend to rip a chunk out of the lip of the plunger. I bought a new one and modified the plunger per sticky and so far so good.
But I haven't really had a good chance to test it either. I've had some heavy fuel situations under a load but not out on the interstate while at speed (which is what caused the problem I think
I kept the kill cable just in case...
).I kept the kill cable just in case...
randyswelding
Feb 9, 2009 10:40 PM
