HELP Shudder problem w/"93" model
Old Jun 10, 2003 | 02:02 PM
ramguy's Avatar
I just installed the new tranny and a new factory lift pump.<br>When it's setting at a idle in neutral or park it's got a shudder or a shake. When I drop it in gear it smooths up until I take off an idle. ??? At high rpm in neutral it seems fine ,no misses.<br>Out on the road it's a constant shudder, but has plenty of power ;D<br><br> ramguy
Old Jun 11, 2003 | 10:19 PM
Bushy's Avatar
Patron Saint of 1st gens
Re:HELP Shudder problem w/"93" model
That's kinda odd..... since you changed the lift pump, did you bleed off any air in the system.???<br>That may be the problem.. are all your connections (fuel) tight?<br>Do you see any difference in smoke/EGT's/boost etc???<br><br>Bob.
Old Jun 12, 2003 | 11:03 AM
ramguy's Avatar
Turns out the new TC is BAD &gt; I noticed a ton of run out in the TC &amp; flex plate &quot;fly wheel&quot;. ??? Anyway I contacted ATS(Clint) and he's got a replacement on the way. <br><br> ramguy
Rafter B
Apr 13, 2008 09:40 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
RedRam410
Feb 2, 2007 10:27 AM
1320
52
Dec 31, 2006 12:05 PM
samtheham
Jan 9, 2003 12:16 AM
