Help me choose 18.5 or 14wg housing
The bigger the exhaust housing for him, the better. BUT he's going to have to have a wastegate for boost control with that amount of power/fuel. There's no way around it. The biggest wastegated housing he can get without upgrading turbos is a 14cm. It's a must. Now you could always go the external wastegate route.....
I do have both housings so I will have the option to try both. Maybe in the future I'll be able to upgrade to a better turbo when I get the $$$$. I've never seen an external waste gate. Where can I get one and how much are they?
Dan, I'm not sure about which injectors yet, either 190s or stage 3
External wastegates can be had on ebay. Some are very expensive, while others are cheap. You dont need anything fancy. To install one, you drill a hole in your exhaust manifold and mount it. Then run either an open exhaust pipe, or plumb it into your existing exhaust pipe. Its a very simple thing. They work a LOT better at controlling boost spikes too than an internal gate. If you cant find one for cheap then its not worth the money. Save it towards a bigger turbo.
As for the injectors, I dont think the 190's will get you much past 300hp. I'm not familiar with the stage 3's so somebody else please chime in on that. A good injector for you to look at are POD's. If you get the thinner washers and tune your pump conservatively then you could definately pull with them. I think people have gotten up to about 385hp on them. Did I miss anything?
I second that. At 4,500 ft he will need to cut off the AFC tang and put in POD's to get it to spool, and it will smoke like a Compton riot (or a Willie Bong) for about five seconds until it does build any boost.
or wait for a better turbo.
scott54
Aug 29, 2007 11:12 AM
CumminsRedneck
14
Jan 30, 2007 01:58 AM
