Help a guy out...
Old Feb 25, 2006 | 07:31 AM
G1625S's Avatar
Help a guy out...
Ok, I'm inserting a copy of an e-mail I received from a guy I met over the summer. He picked up this truck for $1500 right before I get there with the cash. His sig would read:
'93 d-350 club cab LE. 3.55 gears. Getrag. H1C/18. Cranked pump (but nary a puff of smoke when I drove it...though it was quick) His pump doesn't look too advanced, but it rattles like a 24v. Here's the e-mail, let me know what you thing...I'd send him here, but he's only online once a week. Thanks fellas!
''ok ive been paying attention to details
the most fuel milage actual checked i get is 14.3 at 74 mph. i get max 300 miles on a tank of fuel. the boost is 7-8 lbs and exaust temp is775-825 depending on the air temp out side.. ive tried injector cleaner, atf running it and other additives... I took the boost valve /fuel rod and turned it back till it aggrevets me to drive it... i also turned the spring pressure up to elmitate the black smoke some what... but it gets enimick doggy boggy.. all oil leeks are fixed no drips any wheres... dry underneeth... also at 67-69mph the exaust temp is 675 -780 the boost is 4 1/2.. is the set up wrong? what is recomended???? I use the cruise controll mostly on long trips and drive conservitly... what is wrong????? 3:50s gear.
the traffic was heavy and i beat on it today leaving the tollboths on the 528 expressly tonight and i was running 23 lbs of bost 1225 exaust temp at 95 mph.
i seldom drive it that hard usaly 71-74sh it likes.. trans working Good put in a better grad of bearings from miller bearing works great... ''
Old Feb 25, 2006 | 11:28 AM
bgilbert's Avatar
All sounds normal.
Old Feb 25, 2006 | 11:37 AM
G1625S's Avatar
I think he's jealous of my 20 mpg. It's probably the speed that's killing him, right?
Old Feb 25, 2006 | 11:38 AM
Any idea on tire pressures? There's no reason the mileage should be that bad. I would try bumping the timing - engine noise can be deceiving.
I would tell him that you'll take the pig off his hands for $1200.
Old Feb 25, 2006 | 11:42 AM
G1625S's Avatar
''I would tell him that you'll take the pig off his hands for $1200.''
I've tried, a couple times. He woulda taken 3k for it a couple months ago before he moved to Florida, but I couldn't come up with that kind of cash in short order...
Old Feb 25, 2006 | 06:16 PM
BearKiller's Avatar
If he got a Cummins truck for a mere $1500, then he can buy a lot of fuel with the savings.
Taking a $1500 truck and expecting Nissan mileage is like expecting two Christmasses in a year.
Old Feb 25, 2006 | 06:22 PM
Boatnik's Avatar
WHAT? ONLY ONE CHRISTMAS! WHERE DID I GO WRONG?
slothrockit
Introductions / New People
Jul 5, 2008 10:25 AM
rjm022
0
Sep 16, 2007 08:33 PM
sickboy774
Aug 4, 2006 10:21 AM
ratsun
Oct 4, 2005 10:01 AM
natlchamp2k4
16
Jul 21, 2005 10:10 AM
