HELP - 91 12 valve wont start
Old Nov 5, 2014 | 09:55 PM
drewsta's Avatar
I just purchased a 91 dodge diesel, it starts right up and runs great after you bleed the fuel system at the injector - turn it off then it wont start...
need to re bleed... any ideas? fires right up only after cracking the fuel lines at the injectors and bleeding all 6... if you dont it just cranks and cranks..
any ideas ? Thank you.
Old Nov 6, 2014 | 10:54 AM
maybe368's Avatar
Sounds like you have an air leak, thanks captain obvious. It is probably on the suction side, which can be hard to find because they often don't leak fuel. One thing you can do is pressure your fuel tank with 5-10 psi and look for fuel dripping. I had the same problem and it turned out to be a crack in the lift pump...Mark
Old Nov 7, 2014 | 10:28 PM
hot_runner58's Avatar
when mine was doing this, it was the o-ring on the bottom of the fuel filter drain. Cost me the o-ring and 2 hours for the mechanic to find it. I would do as maybe368 suggested and put some pressure to it.
Old Nov 9, 2014 | 08:00 PM
rrgrassi's Avatar
How do you pressurize the fuel tank? Modify a cap?
Old Nov 9, 2014 | 08:57 PM
maybe368's Avatar
You can do that or you can stuff a bunch of rags around the hose. I actually used duct tape to thicken the hose and it kind of threaded into the opening. It doesn't really matter if it leaks, you only need 5-10 psi for a few minutes...Mark
Old Nov 10, 2014 | 11:01 AM
j_martin's Avatar
In fact it's a plastic tank. More than a few pounds of pressure will rupture it.
Most of us use a rag wrapped around a hose, but you can modify a cap for hands free operation. Just be sure you use a regulator to hold the pressure WAY down.
Old Nov 10, 2014 | 03:09 PM
Redtruck-VA's Avatar
I had a leak from my wtr in fuel sensor and just replaced the whole filter with one that had no sensor. Leak fixed...
Old Nov 10, 2014 | 03:31 PM
maybe368's Avatar
In fact, I put 25-30 psi into mine the first time and the tank did not rupture. Maybe it could have, but it didn't. 5-10 is fine...Mark
Old Nov 11, 2014 | 09:29 AM
rrgrassi's Avatar
Ok, makes sense. My air compressor does have a regulator, that can go down to zero.
Old Nov 11, 2014 | 09:59 AM
j_martin's Avatar
I took the regulator off a discarded blown cheap compressor and put an input male and output female air fitting on it.
I use it for:
Testing oil drums for leakage (4-5 psi)
Pressuring fuel tanks looking for leaks. (5 psi through the charcoal canister hose. (gassers)
Clearing water lines in the camper for the winter: (25 psi)
Controlling a die grinder for sharpening chores (50 psi)
Pushing product out of a steel drum (4-5 psi)
Controlling compressed air so I don't blow parts off a computer I'm evicting the dust bunnies from. (10 psi)
It's pretty handy. Would be worth buying a small regulator to make.
TNDODGE
Sep 13, 2012 01:38 PM
Stroked-Z
Oct 4, 2008 11:28 AM
Robbsdpower
Apr 21, 2008 07:05 AM
qcstunter
Jan 9, 2007 04:10 PM
john shufelt
Oct 19, 2003 04:40 PM
