Help!!!!
Help!!!!
i'v been working on my truck today the engines a 93 anyway i parked it in front of the shop worked on it for about 2 hours with on acc listening to the radio ,well i was almost done working on it and decided ,becouse the key was on to start it up and let it idle a few min before i put it away here's my problem i went to start an it wouldn;t ,it only start when you give the fuel ,when canking over it sounded like it wanted to start but wasnt getting fuel , when you step on it ,it ll run but it miss's any ides ?
relocating the toolbox and some seat mods.... i think i have the problem figered out i was talking with my grandpa he thought it might be the lift pump for the fuel , i checked it all i got was sucking sound no fuel , no air , the truck does havefuel in it so i'm going to check the charge pump [as he called it] so far if thats the prob it'll be the second pump in two years that i'v had to replace
my dad's a capt with over 25 years totel .........cheaked the lift pump seemed to be working all right stilll trying to chase down the souce of my problems
Seems to me you're sucking air from somewhere. Also, drain your fuel filter into a clear cup or glass and check if you have any water in there. Other than that, more info is required to figure this one out!
IIRC the VE is able to suck fuel to itself without the LP, but it will shorten the life of the pump.
Hopefully he'll be able to tell us what the condition of his filter draining is! Mine wasn't running quite right when I had some watery fuel... it led to a seized IP a few miles down the road... be warned!
nope no water in the fuel i blowdidid the trans up the tuesday before christmas and i'm doing a gas nv4500 converson an im still gettting the 4500 ready to go in ,funds haven't been quite what id hoped ,though i might have run it dry ,but im gonna fix my IP frist was putting in my 366 spring yesterday an i broked my IP
, what happened was i got sick of trying to solve my fuel problems, an i had the 366 spring sitting there an decided to put the spring in an then work my way to the fuel tank , of couse that didnt work out so hot ,right now i'm thinking it might be the LP ,i didnt want to think it was the problem at first couse i replaced it a year an a half ago
Mark
