help???
Old Jan 7, 2007 | 11:23 AM
no fat chicks's Avatar
help???
i have a 1991 w 250 ctd with a 3 speed no over drive tranny, hx 35 turbo, bully dog fuel pin and four inch exhaust, im still running stock injectors, my problem is that i have these upgrades and i turned up my fuel pump and i am not impressed!! others that i know have trucks stock but with tweaked pumps and they are getting much better results. truck smokes allot, but does not seem to go anywhere? can anyone point me in the right direction??? any pointers? what am i doing wrong? any help would be greatly appriciated!!!!
Old Jan 7, 2007 | 11:42 AM
Begle1's Avatar
You're engine is making probably over 200 horsepower, but you're tranny is responding by turning all of the power into heat instead of motion.
A Hughes torque convertor costs under $400 and is good for around 350 horsepower; a Goerend's torque convertor costs twice as much but is good for twice as much power.
A good torque convertor, perhaps coupled with a shift kit or valve body, is required to put your power to the ground.
Old Jan 7, 2007 | 12:01 PM
thanks i will for sure be looking into that!
Old Jan 7, 2007 | 05:13 PM
First thing I check on a 1st gen is the throttle travel. Make sure you are getting it all. Swapping the return spring and throttle rod holes on the throttle arm makes a huge difference.
Old Jan 7, 2007 | 05:44 PM
Begle1's Avatar
You're just not a very good salesman Dave.
Old Jan 8, 2007 | 01:13 AM
Boatnik's Avatar
Dave's right. You will get a lot more travel than you can use. I had to drill a hole halfway between the two so my cruise control and auto trans would work right. The TV cable sees the same amount of travel but the IP sees a lot more. This is just an adjustment. The cruise control would not settle down on any one speed. It would "hunt" constantly raising and lowering looking for the sweet spot. By drilling a hole in between and moving the throttle link to that point I found the best of both worlds. Oh, the throttle arm is hardened steel. Don't think you can just "pop" a hole in it with a common jobber's drill. I had to use a grinding bit and a Dremel tool being careful to not melt anything.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
