heater hose control valve
Old Apr 1, 2015 | 07:51 PM
cabtruck's Avatar
The valve that stops water from running through the heater core is not working. I can't find one before I put a quarter turn valve in thought I would ask if anyone knows where to get one.would like it to work like it should
Old Apr 1, 2015 | 09:43 PM
Philip's Avatar
NAPA can get them.
Old Apr 1, 2015 | 10:01 PM
Originally Posted by Philip
NAPA can get them.
I believe the one that they will bring in is actually for a gasser truck. And is a 3/4 and 5/8 nipple, instead of a 3/4 x 3/4.
Old Apr 2, 2015 | 09:07 AM
cougar's Avatar
Try
Murray Climate Control 74865 - Vacuum Non-Bypass Closes Heater Valve | O'Reilly Auto Parts
Old Apr 2, 2015 | 07:52 PM
Philip's Avatar
I picked one up with the correct 5/8" hose fittings.
Old Apr 2, 2015 | 09:45 PM
But the ones on our 1st Gen's are 3/4 x 3/4. Not sure why you would have a 5/8 hose, unless someone swapped it?
Old Apr 3, 2015 | 07:56 AM
Philip's Avatar
Mine is 5/8's. Always has been from the day I bought the truck in early 98.
Old Apr 3, 2015 | 08:56 AM
Alec's Avatar
On my trucks the tubing & the hoses are 5/8. Just double checked with the calipers -- thought maybe my memory was wrong.
Old Apr 3, 2015 | 10:51 AM
cougar's Avatar
Mine is 3/4". Wonder if it has something to do with the factory cold weather package mine has.
Old Apr 3, 2015 | 05:02 PM
Philip's Avatar
Yes it is. Even the gasser Dodges up there had larger hoses. I was stationed up there for a year in the USAF. I was a vehicle mech.
Old Apr 3, 2015 | 09:45 PM
Well I learned something new today. I just always assumed the diesels had the bigger heater hoses, compared to the gassers. Guess I was wrong.
Old Apr 4, 2015 | 07:19 AM
Philip's Avatar
The artic packaged Dodges had stuff you would not see down here in the lower 48. The USAF artic pack trucks came with larger heater cores and hose. A battery trickle charger. A battery heater pad. A block heater. The radiator was a little smaller than a lower 48 radiator was. It also had a different antifreeze in it. When it was cold the antifreeze looked like a thin jelly. When warm it flowed like water. The bad part is was corrosive. So you had to keep up on antifreeze service or it would eat out the radiator and heater core.
Old Apr 4, 2015 | 11:56 AM
Very interesting...never heard of that package before. Thanks for the enlightenment!
SOOT4BRAINS
Oct 26, 2010 12:25 AM
Hotwheelbill
Aug 17, 2009 01:51 PM
george7941
Aug 10, 2005 07:06 PM
