Headlight relays with DRL's ?
Old Jan 15, 2008 | 07:07 PM
rainfade's Avatar
Question Headlight relays with DRL's ?
OK so lost the headlights on the way to work.
Didn't feel like working on it in the snow (gotta get a shop built) so took it to the dealer they diagnosed (god help me maybe they got it right for once ) as switch
That sounds right as I could get the lights to work holding the high beam lever
When I get it back and a bit better weather i'd like to put relays on the headlights but wonder if anyone has done it with the daytime running light module ??? and if so some pointers PLEASE.
As I don't need drl's I also wonder if anyone has bypassed the module ? The wiring diagram it doesn't make it look too tough.
Thanks in advance ,
Brian
Old Jan 15, 2008 | 07:52 PM
Jim5870's Avatar
I have done this mod to my truck, my DRL didn't operate afterwards.
( I don't miss it anyway) I think it is because the lower voltage in
DRL mode is not enough to operate the coils in the relays.
Old Jan 15, 2008 | 08:07 PM
woodrat's Avatar
DRL?
wazzat?
Old Jan 15, 2008 | 08:35 PM
Jim5870's Avatar
DRL = Daytime Running Lights
Old Jan 15, 2008 | 08:51 PM
bobva's Avatar
I dont think drl will work this link has small info on drl's
http://www.4crawler.com/4x4/CheapTri...ml#OnLineOrder
Ijust bought a relay harness from ebay $28.90
Link is in my post (bright lights ebay)
Old Jan 15, 2008 | 10:46 PM
ofcmarc's Avatar
Jim Lane was working on a relay setup that was compatable with the DRLs but I havent seen anything on it in a while.
Old Jan 16, 2008 | 02:38 AM
bobva's Avatar
the more I read this link
http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
the more I beleave this guy has a harness that could work with daytime running lights
but I dont have a wiring diagram or a truck to verify this. So its still a guess.
although If A person was to buy the switched power harness and it dont work right it could be easly converted to a standard harness and disconnect the DRL"s
good luck
Bob
Old Jan 16, 2008 | 03:14 AM
bobva's Avatar
On this link
http://www.4crawler.com/Diesel/Cheap...adlights.shtml
the guy says he's a electrical engineer
Roger Brown, P.E.
Old Jan 16, 2008 | 09:36 AM
cootz's Avatar
I've done the upgrade with DRL's. Go ahead and do Jim Lanes relay upgrade. After the upgrade my lights would pulse on DRL mode due to the low voltage going to the relay.
I just unplugged the DRL module for now but I will be connecting them up soon.
According to the FSM, it looks as though the red with black stripe wire from the module harness is the ticket (output to headlight). I'm going to cut that line, and splice it into the highbeam output from the relay, that is #87 terminal. This will work as the relay will be bypassed for the DRL, but everything else will work as it should.
Since disconnecting my DRL module, I now plan on also installing a switch inside the truck to activate/deactivate the DRL's. I like the way the truck looks early evening with just the acc lights on and no headlights.
Old Mar 4, 2008 | 07:56 PM
cootz's Avatar
Just to give ppl an update. I finally finished this last night as stated in the above post and everything works as it should. Relayed highbeams, relayed lowbeams, relayed accessory headlights (switched in with highbeams) and fully funtional (switched) daytime running lights, only when I want them. Look out deer.
blacklab467
Dec 15, 2012 06:45 PM
Dean Snow
Nov 11, 2007 12:40 AM
4RnrRick
Oct 1, 2007 09:21 PM
Ace
Oct 25, 2006 10:57 AM
