headgasket uh-oh
headgasket uh-oh
Well I went over to my uncles today to show him my new parts and when I popped the hood I noticed anti freeze running down the side of the block. So my question is if I retorque the head to about 125 ft lbs and turn down the pump a little will it be ok for a while til I get a gasket and what not
P.S when I went home none leaked out but I kept the boost under10 psi and there is no fluids mixing yet
Thanks,Andrew
Thanks,Andrew
when mine blew it ran fine 5psi more boost and i pressure tested it and was in normal leak down but when i started it to go home it had water in it and a lot of white smoke but it still started back 2 cylinders
Try the retorque, you have nothing to loose but a little time. I've seen new ones seep that had been fresh with o-rings, then a little retorqe and back on their way. So definatley try the retorque, If there's no fluids mixing, retorqe, if it won't torqe up the bolt(s) may be stretched.
Its seen 50psi about 10 or 12 times and 53 or4 a couple time, I'm actually suprised its lasted this long
When i put this gasket in I did the drop test on the bolts and they all rang and they were all in spec on the stretch gage
well did the retorque but still leaks. Going up to cummins in Omaha in a few minutes to get a gasket and some bolts and need the part # FOR THE .020 OVERTHICK gasket, I need this info ASAP
Thanks,Andrew
Thanks,Andrew
