Haze under full boost?
Old Feb 17, 2010 | 11:18 AM
Subliminal's Avatar
Hey guys,
So, I've done most of the basic pump mods, and now I hit ~25psi with the go-fast pedal all the way down.
Today for the first time I noticed some...haze behind me after I left a light (leaving a Powerstroke to enjoy it).
Is haze just a small amount of black smoke? I mean, there definitely wasn't a bunch of black smoke rolling out of the truck, but it was from excessive amounts of fueling...right?
Old Feb 17, 2010 | 11:48 AM
Richie O's Avatar
366 Spring Chicken
I don't worry until it makes the headlights behind me go out. The most I saw on stock 6x.009's was 30 psi. Thats with everything maxed. They did haze a little at wide open throttle. The .016's on the other hand smoke at every rpm and throttle position.
Old Feb 17, 2010 | 12:11 PM
schamran's Avatar
Sorry, posted, re-read, and edited.
Old Feb 17, 2010 | 12:25 PM
JQmile's Avatar
On my truck, including at idle
Old Feb 17, 2010 | 12:33 PM
unixcowboy's Avatar
JQ - you and Ritchie need to replace your AFC spring .......
Mine hazes at idle like pretty much all big sticks do. But as soon as I get some air flowing they clear up.
UNTIL the throttle gets real close to the floor
Old Feb 17, 2010 | 12:49 PM
92smokin blacky's Avatar
try pullin your afc lever out put some pods in and it'll really haze.
Old Feb 17, 2010 | 04:21 PM
93Fury's Avatar
POD's seem to haze no matter what. Even with the afc lever they were still messy.
Old Feb 17, 2010 | 05:25 PM
ChrisLib's Avatar
PODs are dirty and stinky, wish i had the disposable green for some 5x12`s or 14`s, anything actually that would idle clean.
Old Feb 17, 2010 | 05:38 PM
JQmile's Avatar
My engine is dropped about a half a point on compression too, which doesn't help.
Old Feb 17, 2010 | 06:03 PM
Rampage1967's Avatar
Originally Posted by Subliminal
Hey guys,
A properly calibrated truck will run totally clean to leaving a bit of a gray haze at full throttle.
(I set mine for gray haze at full power on a 70 degree day).
These trucks will also leave a black puff just before going into boost.
Old Feb 17, 2010 | 06:35 PM
ZSkibo's Avatar
6x18's here. Hahaha....haze.
Old Feb 17, 2010 | 07:05 PM
Subliminal's Avatar
Thanks. My truck puffs a little white when it's cold (4 hrs sitting at 15 degrees outside or so)...but then doesn't really smoke until I give it full throttle, and then just hazes grey.
Sounds like I'm right where I wanna be.
wyattearp29
Oct 18, 2015 10:33 PM
ElkyRacer
Oct 10, 2008 04:25 AM
West Coast
Jul 4, 2007 10:25 AM
tomd
Dec 8, 2006 07:07 AM
j
Nov 14, 2003 09:38 PM
