Hard starting issue.
Old Jul 24, 2010 | 11:58 PM
Bogurt's Avatar
Over the last couple weeks, my truck has been taking longer and longer to start in 80 degree weather. Truck will start easily after it has been running, however, If left to sit for a period of time, it will just crank forever and not fire. Or sometimes it might fire after a while????? If I push start the truck, it fires immediately with no problems at all. I did some research and assumed an air leak in the fuel. I have since replaced my fuel filter and deleted the fuel heater with the shorter fuel filter fitting. I couldn't find leaks anywhere else. The truck has no noticeable loss in power. Starting is not affected by how hot the ip is. I tested this by attempting to start hot and cold(after spraying an upside down can-of-air on the pump.) Any insight would be great.
Old Jul 25, 2010 | 01:09 AM
jimbo486's Avatar
I just started thinking about the pump but you said you tried cooling it with a can of air. Have you tried pouring warm water on it after it's been running for a while? Not cold water of course.
Old Jul 25, 2010 | 02:21 AM
Bogurt's Avatar
Tried water first, but it was taking forever to cool the pump off all the way.
Old Jul 25, 2010 | 07:32 AM
You're getting air. Pressurize the fuel tank a little bit (wrap a rag around your air nozzle, you only want a few psi) to make fuel come out where the air is getting sucked in.
Old Jul 25, 2010 | 01:23 PM
Bogurt's Avatar
thanks, ill try that.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
BNC04
Sep 26, 2006 02:33 AM
BNC04
Sep 11, 2006 03:25 PM
