Gutless
Old Jul 14, 2009 | 09:45 AM
LAME's Avatar
Gutless
I recently acquired a 1993 W250, Extended Cab, with a auto. I have been able to solve most of my issues with searching and the sticky (death wobble and electrical issues). All I have done to the pump is 2 turns on the smoke screw, and rotated the fuel pin 180*, which only made a slight change. I figured I would wait on gauges before doing anything else, since it is good enough for running around town when I need the truck.
Last night I went and picked my Jeep out of storage so I could get that ready for wheelin this weekend. Jeep and 16' trailer weigh about 4800# combined. I had the throttle on the floor mat the entire ride home. I thought I was towing with a 6.2 GM Top end was about 65mph, and it took forever to get there, as it never seemed to rev. I am not worried about the power for the long term, once I get some mods done. I am worried about driving 450miles this weekend at a snails pace
Is moving the throttle linkage going to be about all I can do to to help without gauges? The lever is bottoming out on the limit screw right now.
Or do I just deal with it for now?
Old Jul 14, 2009 | 10:18 AM
Ace's Avatar
Ace
Have you serviced the trans, and is it shifting into OD? If not and it's slipping now, I doubt you'll make it 450 miles with a trailer behind you.
Old Jul 14, 2009 | 10:44 AM
LAME's Avatar
Trans shifts great, OD is functioning as it should. I did not notice any odd increase in RPM that would make me think the trans is slipping.
PO claims fluid and filter was changed 5,000 miles ago. It also has a AUX tranny cooler under the driver side cab extension. Is that normal, or a dealership hack-on?
Old Jul 14, 2009 | 10:55 AM
Are you getting full throttle travel?? http://www.youtube.com/watch?v=4DzcO...eature=related
You could advance the timing for more top end power.http://www.youtube.com/watch?v=IZunLqJwWcA
Old Jul 14, 2009 | 10:57 AM
Ace's Avatar
Ace
Originally Posted by LAME
PO claims ...
Uh, huh. 1st things first. Pull the pan, inspect/replace filter and fluid. No point doing anything else until that's taken care of - for sure. How many miles on it?
Old Jul 14, 2009 | 11:03 AM
LAME's Avatar
124,000 miles.
I'll check the vids
Old Jul 14, 2009 | 11:22 AM
cougar's Avatar
Check for boost leaks. Hows your fuel filter?
Old Jul 14, 2009 | 12:31 PM
Mattster's Avatar
x2 with what Cougar said. Boost leak would really make it gutless.
Old Jul 14, 2009 | 12:36 PM
Ace's Avatar
Ace
Is it making alot of black smoke?
Old Jul 14, 2009 | 12:43 PM
LAME's Avatar
No smoke at all.
Gonna go get some filters during lunch.
Old Jul 14, 2009 | 01:06 PM
Ace's Avatar
Ace
Kinda rules out the boost leak idea, then...
Old Jul 14, 2009 | 02:40 PM
i still think its a throttle travel issue
Old Jul 14, 2009 | 03:09 PM
peobryant's Avatar
That would be the first thing I would check. That, combined with a sloppy auto will make a real dog.
Old Jul 14, 2009 | 03:31 PM
LAME's Avatar
I think it might be the throttle issue as well.
Could also be that I have not driven a first gen since 1996. I really don't "know" what they really are supposed to be like stock.
Local Napa didn't have filters, so I have to go to the warehouse on the way home.
I assume bad tranny symptoms are the same with a diesel, as they are with a gasser?
Old Jul 14, 2009 | 03:59 PM
Make sure the little tube from the manifold to the top of the injection pump is not cracked or loose.
A trans problem is a trans problem, does not matter what the powerplant is.
