Got a little problem
Old Jul 30, 2008 | 09:10 PM
sleeperman's Avatar
I adjusted the timing on my truck over the weekend and when I did I used a strap to pull it over. When I pulled it over I forgot to losen up the bottom bolt and nw the pump leaks fuel. How can I fix the leak? And where can I get the parts from to fix it. The truck still starts and runs but it is a little hard to get started like there is air in the lines once it is started it runs fine.
Old Jul 30, 2008 | 09:16 PM
SkinnyBTN's Avatar
Where is the leak? From the pump top, where it breaks apart?
Old Jul 30, 2008 | 09:38 PM
sleeperman's Avatar
Where te pump splits apart the crack in front of the injector lines connect.
Old Jul 30, 2008 | 09:59 PM
ofcmarc's Avatar
I think (?) that you can undo the injector lines from the back of the pump then unbolt the back half. Then carfully slide it back and sneaky pete a new oring in there with out disassembling the pump. I guess this was a comon trick for the VW 4cyl VEs back in the day. Do a search. it was disscussed a while back But I can't remember the thread.
The_Mexican
27
Nov 13, 2006 02:52 PM
Mexstan
Sep 16, 2006 05:29 PM
JW3
Mar 15, 2006 08:23 PM
