good news!
Old Apr 16, 2009 | 05:02 PM
oilcan64's Avatar
good news!
today pops and i went to PA and picked up the bed from tdimark, wow is that thing in great shape! yesterday i had a guy stop buy and offer me 1200 for my utility body - still waiting for finalization...so i will have money to buy gauges and start fooling around... i figure ill sandblast the frame from cab back and the entire bed- chassis saver bottom of bed and frame and for now just primer the bed so it matches the color of the truck eventually ill paint it
i just bought oil and filter, wow is it expensive...didn't have enough to get tranny fluid...its 10 bucks a quart
here's a good one, my friend got his grandfathers truck a 2000 f250, lariat, 6' bed extended cab..the truck looked brand new immaculate with gps, dvd and the whole nine, made a downpayment of 2000 and is paying off the other 3000 well today he took it to emission and his transfer case went... i had to laugh at that poor ford, such a nice truck at such a great price i guess all those years of plowing finally caught up with him
man am i glad i bought a ctd
thought id share the news
Old Apr 16, 2009 | 05:04 PM
dodgethis91cmns's Avatar
sweet man! i sold my utility body for like 300 bucks it was old and rusty but that was almost all the money i needed to get my new one!
peobryant's Avatar
Congratulations Justin, I'm glad to hear your getting started,
Old Apr 16, 2009 | 05:11 PM
oilcan64's Avatar
thanks guys im really pumped, cannot wait to roll smoke
Old Apr 16, 2009 | 05:25 PM
Benjamin b2's Avatar
anymore, im excited to clean up and put air to all the unburnt fuel coming out my side pipe, like intercooled and an effecient turbo for my non ic injectors and 366 spring. i guess i grew out/got tired of smoke and want more power cleaner
Old Apr 16, 2009 | 09:40 PM
RollinCoalSmoke's Avatar
Congratulations Justin. Don't sandblast the outside of the bed it will most likely warp the metal and it will look all wavy when you paint it. There is other blasting medias to blast with but i'm not sure what you need. Good ole back breaking scrubbing and block sanding does wanders for a used bed to get it in shape to paint. I was painting my 93 and I didn't notice the paint cup was leaking---So I have a re-do on the drivers side. Good luck with it
Old Apr 16, 2009 | 11:35 PM
must be a pretty good service bed, are you gonna paint the whole truck or just match the bed to the cab?
Old Apr 17, 2009 | 06:42 AM
JD730's Avatar
Having done 2 cab back sand blasting jobs I'll offer some advice.
Get a big canvas or sheet to cover the cab, it still going to be dusty, but its not as bad.
Drop the fuel tank and pull the wiring harness from the rear part of the frame, coil that and the fuel lines up and put them under the cab. I've had issues with the lower part of the U on the fuel tank side rotting out. I had to add pieces to the frame on both the ones I did. The last one was really bad, had to add a piece of 1/4" plate to the side and bottom from about a foot forward of the cab to halfway up the arch in the frame.
Check your spring hangers carefully. I had to make new ones on both trucks I did, 8 spring hangers all together.
I wrapped a rag and tapped in around the pinion and brake drums, I haven't had a problem with either one doing that.
Here's the front one before I finished it, I added gussets to it.
Here's a pic of the rear one I made, I changed the design on the next one. Had I been thinking I would have made a set of drop hangers like DNRCustom does and eliminated the axle block. But it works.
Old Apr 17, 2009 | 07:36 AM
TIMMY22's Avatar
Pics of mine...
Old Apr 17, 2009 | 07:46 AM
oilcan64's Avatar
thanks guys
ill be sure to blast under the bed, i'll keep it low pressure maybe 90 - 110 psi but the sides, depending if i can rent my friends compressor and blaster ill da it to bare metal
ktpauley
Jan 9, 2011 01:44 PM
torquedcummins
Dec 9, 2004 12:32 AM
Don M
18
Jul 15, 2004 07:25 PM
tlea7
Apr 22, 2003 10:31 AM
