goerend or suncoast?
Understand he is a busy guy, sometimes you can't get a hold of him right away.
I remember the fix they used a newer 47 case that has a different reverse band setup and swapped all of his internals into it.
He just plain knows trannies pretty well. I went through with him over the phone one time on a trans that had many problems and his help over the phone was outstanding. I know more about them today because of him.
Mike on here (JD730) knows alot about First gen trannies as well and he can lead you in the right direction, He did a 47 swap in his truck. I met Mike in person and hes a genius.
edit- I just saw JD730 replied in this thread,
the reason Goerend's website is a little scary is becuase i'm sure he would rather be called up and talked to on the phone, alot of his stuff is custom made to your applicatin sometimes and does'nt just sit on the shelf waiting for a buyer, That is what he told my Dad on the phone.
Also I asked hima bout the Warrenty, he said plain and simple... you break it I fix it... I said what about if I break an input shaft or grenade a flywheel and damage it? How much to fix it? He said... If it breaks or gets damaged... i WILL fix it... You cant beat that!
Firstgenfanatic
Feb 16, 2010 08:57 PM
dstad
Mar 19, 2009 11:45 AM
