Glow shift fp gauge problem
Old Sep 20, 2010 | 05:54 PM
Onemoparnut's Avatar
I put a glow shift 100 psi fuel pressure gauge in a few weeks ago and it has been working fine. Today it started jumping all around the full range of the gauge. I put a manual gauge in the same fitting and fuel pressure is normal. I checked the ground and it is good. The gauge only does this while the engine is running. I even tried turning the key on and shaking the wires around at the sender and it didnt flinch. As soon as it starts it goes nuts again. I unhooked the wires from the sender and checked it with an ohlm meter and the resistance was jumping from 6 to 36 ohlms. I am assuming that the sender is bad but I just wanted to make sure I didnt over look anything.
Old Sep 20, 2010 | 06:50 PM
dieselJon's Avatar
Did you run a ground straight to the battery? Try that first.
With any Autometer, and now Glowshifts, I recommend a power line straight from the batter and a ground to a grounding point the goes straight to the battery.
If people would do this, the gauges work no problem.
Old Sep 20, 2010 | 06:51 PM
JJK98CTD's Avatar
Bill, you can put in a snubber or a needle valve to stop the pulsations, Or like you said you have a bad sender. I've had mine on my 24v for two years and no problems.
Good luck,
John
Old Sep 20, 2010 | 07:11 PM
I have a snubber in it already. It has been working fine for 2 weeks. I will try the ground to the battery.
bryson711
Aug 16, 2015 12:40 AM
Big Red 97'
Aug 17, 2009 05:43 AM
rustybudweiser
Jan 28, 2008 01:50 PM
oldblues
Dec 17, 2007 09:30 AM
dieselfuelonly
Oct 17, 2007 09:26 AM
