Getrag question
Old Jun 11, 2009 | 07:43 PM
ofcmarc's Avatar
Originally Posted by apwatson50
Does anybody think that with that much pipe hanging out there, it might fatigue and crack/break one of the lower fittings? A bracket off of one of the pto cover bolts might be nice?
It dosent weigh that much but I have contemplated a bracket for it along with a trick little dipstick......
Old Jun 11, 2009 | 11:54 PM
BearKiller's Avatar
If you do the hose thing, why do you need a tee?
The TEE is so you can also employ a neat little dip-stick in the center of that cap and thus monitor the fluid level.
On my Ford/Cummins, it is 2WD, so not quite so complicated to accomplish.
On it, I first screwed in a 1/2 X 3/4 Street-Ell, then an upright length of 3/4 nipple, then a pipe-cap with dip-stick welded in the caps center.
On it, I still have to crawl under to add the fluid, but that is soon going to change.
Also, to eliminate having to crawl under to actually check the little dipstick, I am going to scavenge some of those long cable-style dipsticks from old cab-over trucks and custom fit them to slide inside the clear hose that comes up under the hood, thus I will be able to check the transmission fluid as easily as I check the engine-oil.(and THEN there will be no need for the TEE)
Old Jun 12, 2009 | 12:56 AM
Ace's Avatar
Ace
I can check the Getrag fluid without ever touching the truck:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CTD_33.jpg
It started showing on the sight glass at around 5qt, which roughly equated to the stock fill level with the Fastcoolers. I've since moved the sight glass as far up on the PTO cover as possible and it now starts to show at 6qt, which would be about a 1/2qt overfill relative to the stock fill measure.
Old Jun 12, 2009 | 02:27 AM
gadget.35-06's Avatar
A sight glass from a semi-hermetic Carlyle(Carrier) or a Copeland commercial air conditioning compressor would lend itself well to that application.
Old Jun 12, 2009 | 06:24 AM
SeanB23's Avatar
I have more confidence in a Getrag G360 than any NV--five- or six-speed.
I see old half-a-million-mile abused neglected Getrags, with maybe two quarts of old watery "mystery-fluid" in them, still hauling big loads down the road.
I also see numerous NVs in the cowboy trucks that are all to pieces.
To make any truck-type transmission last, you have GOT to drive them LIKE A TRUCK, not a Mustang.
Sigh.
Well, after replacing the nasty old mystery oil in my 'Rag with 5 2/3 quarts, it still groans in fourth gear between 35 and 40mph, just like it did before. That sound is most un-nerving. Above 40mph, the 'Rag is happy as a bird.
At least it isn't getting any worse now, I suppose...
At what speed you guys usually shift from third into fourth ? Third just runs out of legs for me above 35mph, and this is with the 3200rpm spring, fuel turned up, 16 sq cm turbo, etc.
Maybe I should mess with the other IP controls ? It does put out a big cloud of black smoke every time I shift into third and accelerate.
TIA, as usual, gentlemen.
Old Jun 12, 2009 | 08:47 AM
apwatson50's Avatar
I can comfortably tow grossing 16k up the steep passes in 3rd at 35-40 without what I feel is "wrapping" the engine out. I think I can get to about 45 pretty easy in 3rd. I wouldn't go to 4th under 40 unless you're just loafing.
Sounds like you've got something that is not adjusted correctly. Unless you have 4.10 gears?
Old Jun 12, 2009 | 09:26 AM
RollinCoalSmoke's Avatar
ofcmarc & BearKiller those are good ideas. I like the idea of being able to check it under the hood. I may try this and look over the situation to do the transfer case too. BearKiller if you can't find an old dipstick from a cabover try to modify an old speedometer cable. Good ideas guys.
Old Jun 12, 2009 | 09:50 AM
jmd025's Avatar
I havent really run it out in a while, but I think I remember seeing nearly 60 in 3rd?
My tranny HATES trying to accelerate in 4th at 35-40 mph! It sounds like a den full of badgers.
Old Jun 12, 2009 | 09:52 AM
apwatson50's Avatar
That's because you're lugging it, don't lug it they all hate it.
Old Jun 12, 2009 | 09:55 AM
jmd025's Avatar
I know this
Old Jun 12, 2009 | 10:02 AM
apwatson50's Avatar
I know this
Oh sorry, I wasn't paying attention and thought you were the original poster, my bad...
Old Jun 12, 2009 | 10:23 AM
jmd025's Avatar
Its cool!
Old Jun 12, 2009 | 10:41 AM
PapeCAT's Avatar
Extra Growling in 4th between 35-40 could mean that you need to shim up the mainshaft a bit... you could be running a bit TOO loose.
Old Jun 12, 2009 | 10:55 AM
apwatson50's Avatar
Good point, but main-shaft or counter-shaft, as the counter-shaft would be unloaded in 4th, just floating around in there, rattling back and forth.
Old Jun 12, 2009 | 05:27 PM
Yep, that groaning noise is known as gear rattle. Mine does it too.
