getrag 5 speed question
I have a question for you guys with getrags.
Does your release bearing always spin no matter if the clutch is engaged or disengaged. Mine does and i would think that would wear it out pretty fast.
Just curious if they all do that
thanks in advance
thanks in advance
Your going to want to look into it. Is the pedal not coming back to normal position? Why is there pressure on the fork? There may be some thread adjustability at slave and/or master rods. Because you are correct in the concern with constant spinning wearing the bearing out.
That is the early bell housing ( The later ones the fork is internal). I have one like that but I don't have it put together yet. I was thinking about rigging a return spring on the fork. I did that on my jeep and it worked well.
I'm hearing a slight chafing sound as I'm driving. When I come to a stop, the chafing sound slows to a stop a few seconds later. Do I have the same problem as Axle_Burns? Sorry 'bout the thread-jack.
It may very well be that the bearing is always in contact with pplate in most hydraulic actuated systems. Had not put any thought into it previously. It is a bit odd based on prior knowledge and experience. Here is another thread discussing it http://www.jalopyjournal.com/forum/s...8066&showall=1
Big Bob
27
Dec 14, 2004 03:40 PM
