gauge gizmo
gauge gizmo
alright im about to order my pyro (isspro preturbo colorcoded) and i noticed geno's has a pillar holster called the gauge gizmo for 86-93, anyone ever used these? and when i mount my pyro where do i drill on the manifold, and whats the best way to do it, (I.E. with engine running, remove turbo, grease on bit/tap,shop vac, anymore???) well i feel like i am looking over the edge and pouring gallons of oil down it with my teflon shoes on, im ready(i hope)
I would say that would be a bad idea for safety reasons. It will get hot there and with a moving fan in the engine bay you wouldn't want your clothes to get caught in it.
I have put many of these and have never had a problem. Just use the grease on the drill bit and tap. After its done start the truck and let it idle, dont rail on it!!! All will be good.
I agree with Dodge359, if your scared after you drill simply pull the intake hose off and watch the impellar while someone cranks the truck. If it does'nt turn just kill the truck and rotate the impellar backwards and it will fall into the exhaust. Done Deal.
Yup, and you don't even need the grease on the drill and tap trick. If anything gets stuck you can clear it by turning the turbo back and forth.
I read one thread somewhere where they put a solid gasket between the turbo exhaust inlet and the manifold... drilled and tapped, took the bolts loose and moved the turbo a little (creating a crack between the manifold and the turbo) and started it for a few seconds; that blew all the shavings out the crack. Removed the solid gasket and tightened her up and all was well.... looked like it worked. PITA....
alright i think ill go with the grease on drill/tap and ill use a magnet and then start/check turbo. and is there anyone out threre with the gauge gizmo from geno's. and is the isspro black gauge with colored numbers, illuminated?
I am running a similar gauge pod and it works fine. The bad thing is you have to drill holes in your pillar but, oh well. My next one will be the full pillar 3 pod.
360ramcharger
04-27-2006 07:07 AM
Battering Ram
50
11-19-2004 09:20 AM
