G360 Speedo Gear required
Old Oct 15, 2007 | 03:31 PM
ve6old's Avatar
Getrag G360 Speedo Gear required
Help!
This is my first time on this site and am looking for a Speedo drive gear for the Getrag G360. This is the nylon gear on the output shaft and I believe it is 20 tooth. They seem to be extremely hard to find.
Any help would be appreciated as the tranny is apart right now waiting for reassembly.
Bill in Alberta
Old Oct 15, 2007 | 08:08 PM
edwinsmith's Avatar
Are you sure it's 20 teeth? Seems very wrong. I have one but it's 30 teeth.
What year is your truck? You should fill out your sig with some vital info.
On mine it has a cable drive and also has a reversing reducing gear in the line otherwise the speedo runs backward.
Later years have an electronic pickup.
Edwin
Old Oct 15, 2007 | 08:46 PM
dpuckett's Avatar
He is talking about the drive gear- on the output shaft of the tranny. They are available- I found one last spring for my 90. They are about $80 new, and only a few places have them (DC NOT being one of them, IIRC). I dont remember the part number, but if I get time, I may do some searching.
Daniel
Old Oct 15, 2007 | 09:00 PM
ve6old's Avatar
Hi Edwin
The truck is 92 and it does have the electronic speedo adapter.
and Daniel thanks - if you do happen to locat it will be greatly appreciated
Old Oct 15, 2007 | 09:09 PM
edwinsmith's Avatar
The part number for the 30 tooth gear I have is:
1-52068152
Edwin
Old Oct 16, 2007 | 12:28 AM
Chrisreyn's Avatar
Ed, i think you are looking a the Pinion drive , while VE is talking about teh worm gear. the worm gear is 20 teeth and rides on teh output shaft in the tail assy, while the pinion drive varies with gearing, transmission and such and is what powers the VSS...it varies in tooth count based on gear ratio, tire size and trans. style.
I located the worm gear thru the local dealer, IIRC it was gonna be around $100 but I wrecked the truck before I got around to replacing it....
Old Oct 16, 2007 | 02:10 AM
edwinsmith's Avatar
All the ones I've seen are steel so I immediately assumed he meant the nylon gear that goes in the side. Sorry.
Edwin
Old Oct 16, 2007 | 04:39 PM
dpuckett's Avatar
It is steel on the inside diameter of the gear, and plastic on the outside.
DP
Old Oct 16, 2007 | 06:33 PM
ve6old's Avatar
That is correct nylon outside of steel sleeve.
Old Oct 17, 2007 | 06:09 PM
dpuckett's Avatar
Here is the link to drivetrain.com. There were only a handful of shops I could find on the web, and they had the best price. I think the price on the list is a little lower than what I was quoted- I think it is around $80 now. Part number is ALT4549212. Drop the "ALT" for the MOPAR number.
DP
Old Oct 17, 2007 | 09:17 PM
ve6old's Avatar
Drivetrain.com was one of the first places I contacted with no luck - they had just sold the last one they had and couldn't suggest any other source. Also didn't know if they were going to be receiving any more as new parts for the g360 no longer available.
Will keep trying tho - - -
Old Oct 18, 2007 | 09:40 PM
bgilbert's Avatar
You ever try www.zbag.com call em and see if they would part with one from one of their cores?
Old Dec 13, 2007 | 08:26 PM
Ceejmo's Avatar
Try Mac's Standard Transmissions. They are in Houston. This is the place where I get my parts.
Subliminal
Nov 5, 2011 08:44 PM
TJE
Mar 9, 2011 06:48 PM
Rednecktastic
13
Jun 6, 2009 10:51 AM
mhuppertz
Aug 19, 2006 09:17 AM
