G360 shifter boot replacement.
Old May 16, 2017 | 05:24 PM
edwinsmith's Avatar
I couldn't find a shifter boot for my G360 trans. Nobody including the trans rebuilder had them. I used a Dorman # 614-001 CV boot kit from AutoZone. I cut off the bottom ring and used the clamp I had on the old boot and a Tie-Wrap on the top end around the shifter. I pushed it down as far as I could below the raised ring on the shifter. It isn't perfect but it keeps the oil in.
Edwin
Old May 17, 2017 | 09:17 PM
Daytrepper's Avatar
I used one from a G56, fit perfectly.
It doesnt use a clamp on the G56, but you can still install the original clamp from your G360, just make sure not to over tighten it.
AKBOSSMAN
Mar 1, 2013 04:19 AM
Subliminal
Nov 5, 2011 08:44 PM
DevilzTower
Jun 28, 2010 12:25 PM
95black2615
Oct 8, 2008 03:34 PM
u.s mma
May 19, 2008 09:00 PM
