G M ALTERNATOR IN A 1st. GEN. ???
[QUOTE=BearKiller;2510558]Mr. JIM LANE,
Please, what is the outside diameter of the pulley on your Leece-Neville ??
The stock Dodge pulley is 2.3", give or take.
Many thanks.
[/QUOTE
BK
The outside diameter of the pulley is 2 9/16 I will have to remove the belt t get the dimensions where the belt rides.
I am not sure what the pulley ratio is but the smaller the pulley the higher your output will be at an idle.
The acceptable Pulley Ratio Range 2:1 to 3:1
Jim
Many thanks.
[/QUOTEBK
Jim
Jim
No need to remove the belt and measure; I can work with that.
Which leads me to my next question :
When O.D.s of these pulleys are given, are they meaning the total outside measurement, or the measurement of the belt-riding surface ??
To come up with the pulley ratio, I will need to determine the crank-pulley diameter and do some math, right ??
The size of all the other pulleys should have no bearing on the ratio between the crank-shaft pulley and alternator pulley, as however much ground the belt covers at the crank, it is covering an equal amount at the alternator, right ??
Well, I have my 555 Alternator and another Group 31 battery, thank you Mr. Lane for all your input, a true asset!
Now as soon as I am finished fixing holes in Metal parts, (head gasket) I can install them!
I now have two, a 140-amp and a 160-amp; and, I am almost owner of another 160-amp.
I sort of feel like I have "arrived"; for years, I have heard mention of Leece-Neville alternators, in posh and reverent tones, whenever the ultimate in alternators was mentioned; no one ever seemed to have actually seen one, but we did believe that they might really exist.
THANK YOU again, sir.
The Crank pulley is 6 1/6" in diameter.
Correct, the Crank and the Alternator pulley are all that you need to find the ratio.
THANKS
Jim
[QUOTE=BearKiller;2512304]Well, now that I have been diagnosed and we know what is wrong with me, is it treatable by therapy and a support group, or am I terminal ??
We can go to therapy together, I have a bunch of the 100 amp ones they used in the 80's, I just cannot pass them up at the crusher, and I have never had one fail. HELP!
Mister Jim Lane,
How far apart, center-to-center, is the new bolt-hole from the old one ??
Also, does the L-N "ear" end up flush with the stock alternator position, or is it located the thickness of the stock bracket forward ??
I can't tell for certain in the picture.
Thanks.
Mister Jim Lane,
Thanks.
Thanks.
The spacer is 2" the Leece Neville has a ISO J-180 Mount which is just under 4” or 3.935to be exact.
THANKS
Oops this should read:
The Crank pulley is 6 1/2" in diameter.
Ok can somebody good at math check and see if I was paying attention back in High School?
Crank~~Alt ~~~~Ratio~~~~~RPM~~~Alt.RPM
6.50" / 2.70"= 2.407407407:1 x 800= 1925.925925
I found this ratio chart and it looks like I was pretty close.
http://www.penntexusa.com/Pulley_Ratio_Chart.htm
So at a fast idle the alternator will put out 100-amps.
Jim
THANKS
Jim
