😁fuse link problem
Old Aug 23, 2015 | 08:20 PM
charlie128's Avatar
😁fuse link problem
Ok here goes cranked truck put in reverse and truck died all within 20 seconds, found orange fuse link burnt up on the driverside fender it goes to a red wire that also has a white fuse link wire attached to it the red wire goes into the fire wall what does this red wire go to or operate thanks for any help you may give
Old Aug 23, 2015 | 08:24 PM
charlie128's Avatar
I'm thinking that red wire goes to a clear block connector in the dash but not sure I got hot and tired of laying in the floorboard looking at wires I also a fuse in place of of the fuse link and it blows fuse soon as to turn key on to "wait to start" position so I know I've got a short somewhere ?? Thanks again
Old Aug 23, 2015 | 08:35 PM
j_martin's Avatar
Just for grins and giggles, are you going to tell us what truck yer talking about, or are we supposed to guess?
Old Aug 23, 2015 | 08:48 PM
charlie128's Avatar
93 w250 4wd auto cummins
Old Aug 23, 2015 | 08:53 PM
charlie128's Avatar
Old Aug 24, 2015 | 12:33 AM
RamGuy84's Avatar
Check your wiring going down to trans you could have a shorted out wire .
Old Aug 24, 2015 | 09:51 AM
charlie128's Avatar
Ok, thanks ill check there later this evening and see what i can find
Old Aug 24, 2015 | 10:12 AM
maybe368's Avatar
Do a search of "fusible links". there have been many posts about this. I believe that there is at least 1 thread in the sticky about taking care of this...Mark
Old Aug 24, 2015 | 01:33 PM
j_martin's Avatar
Ignition switch powers a blue wired circuit protected only by a fusable link that goes all over, including the grid heater relays, the IP, and the transmission OD circuit. Lot's of opportunity for a frame short.
Old Aug 24, 2015 | 02:37 PM
charlie128's Avatar
So I'm looking for a needle in a haystack haha
Old Aug 24, 2015 | 07:05 PM
jimbo486's Avatar
Not sure if this will be hard to read or not. I tried to keep the text centralized as best I could which is why I wrote so small. Not too long ago, I traced the wiring as best I could throughout the wiring schematics in the FSM for my '90 and labeled the fusible links with what I could find. Here's what I came up with. I've had a few others ask if I could put together a better layout including text. I'll do what I can as soon as I can and post a thread.
If you're certain it's the 12ga. Red wire on the other side of the 20ga., 40amp Orange fusible link, that powers some of the interior and exterior lighting.
Old Aug 24, 2015 | 07:26 PM
j_martin's Avatar
Not really. Just look it up on the diagram and look for the blue wires.
It ain't rocket science, but it does take a little bit of thought.
bigjohn92
Nov 25, 2010 01:32 PM
Robert in W. Mi
Sep 16, 2009 08:46 PM
Totallyrad
Sep 11, 2006 05:28 AM
Evildiesel
Nov 18, 2005 04:12 PM
ob1kobi
Feb 17, 2005 10:14 PM
