Full Flow Coolant Filter Idea. Thoughts?
I was at a jobsite recently looking over a Cummins genset. It was one of the coolest things I've seen in a while. 2.7 MW genset, which is a 78L 18 cylinder Cummins motor that makes 3,800 hp at 1,800 rpm.
One thing that got my attention was the coolant filter setup. It seemed to have a full flow coolant filtration system. I like that idea.
It is my opinion that a coolant filter is VERY important on a hard working engine, so I plan on adding one after doing some searching on the subject and finding out the opinion of Cummins, Inc. regarding coolant filters on the B-Series engines.
I read through Cummins Service Bulletin Number 3666132-02 regarding Coolant Service. Coolant filters are described as "mandatory" by Cummins, Inc. on B-series engines in hard-use/commercial applications.
According to a Development Engineer at Cummins, the only reason that Cummins-equipped Dodge trucks do not have a coolant filter is due to space restriction under the hood. This is plenty enough reason for me to add one, but I want a full flow filter. I know a huge number of diesel owners who have added a bypass filter, but have always been discouraged from trying a full flow filter. I decided REALLY to find out why.
A long call to Cummins, Inc. led me to a very informative conversation with an engineer in the Experimental Engines department.
He said that a full flow coolant filter was simply the best way to go on a Cummins, and the only reason to discourage the use of a full-flow coolant filter (and the reason that so many people use bypass style filters) would be the large size of a filter that could flow a high enough volume of coolant that it wouldn't become a point of restriction in the cooling system, even on a B-Series motor. It would never fit under the hood of a light-duty truck.
So I am now on a search for a large, high flow coolant filter and filter head to build a frame mounted coolant filter. I plan on routing my heater hose (before my evap. shutoff valve) down the firewall to a frame mounted filter and back up.
My question for the experts is this (it crossed my mind after I got off the phone with Cummins
). Would the water pump on our trucks support this? Not the filter, necessarily, but the path back to and from the filter. I'm figuring 5-6 feet of heater hose each way, straight uphill on the return trip from the filter. What do you guys think?
He said that a full flow coolant filter was simply the best way to go on a Cummins, and the only reason to discourage the use of a full-flow coolant filter (and the reason that so many people use bypass style filters) would be the large size of a filter that could flow a high enough volume of coolant that it wouldn't become a point of restriction in the cooling system, even on a B-Series motor. It would never fit under the hood of a light-duty truck. So I am now on a search for a large, high flow coolant filter and filter head to build a frame mounted coolant filter. I plan on routing my heater hose (before my evap. shutoff valve) down the firewall to a frame mounted filter and back up.
ralphyboy
Jan 17, 2008 08:35 PM
8mpg
May 22, 2006 01:35 PM
SuperDave4x4
Jul 18, 2005 08:23 PM
